Question about Intel D101GGC Motherboard
Dma What is dma , i have d101ggc with 2.8ghz -D Processor ,is dma is enable in my motherboard by default , or i have to enable it and can i cause trouble for me or corrupt my windows or any software
  • 44 Answers
DMA is Direct Memory Access : http://en.wikipedia.org/wiki/Direct_memory_access
It should be automatically enabled, but if it is not there will be no damage. DMA simply speeds up access.
Posted on Dec 22, 2007
Tip
Turn Direct Memory Access (DMA) on or off You must be logged on as an...
You must be logged on as an administrator to perform these steps.
is usually turned on by default for devices such as CD or DVD drives that support DMA. However, you might need to turn on DMA manually if the device was improperly installed or if a system error occurred.
  1. Click to open Device Manager. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Double-click IDE ATA/ATAPI controllers.
  3. Under IDE ATA/ATAPI controllers, for each item that has the word Channel as part of its label, right-click the item, and then click Properties.
  4. Click the Advanced Settings tab. Under Device Properties, select or clear the Enable DMA check box, and then click OK.
on Dec 14, 2010 | Computers & Internet
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
New burner is taking 6 hours to burn dvd
Check the DMA settings on your DVD device, usually found under Device Manager->Properties. It sounds as though DMA is OFF, causing this extremely long burn time. You could also check your BIOS settings for the Hard drive(s) and DVD devices you have installed. Make sure that DMA is enabled for all of them. You'll see increased performance when enabled and set to ON.
Dec 11, 2009 | Computers & Internet
Micro star mainboard ms-6163
Hi
MS-6163 Pro Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports up to Ultra DMA 33 operation mode.
MS-6163 Pro - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=340&maincat_no=1
**** Other MS-6163 ****
MS-6163FC Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163FC - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=341&maincat_no=1
MS-6163VA - Systemboard IDE controller utilises VIA VT82C596B Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163VA - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=342&maincat_no=1
MS-BX Master Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-BX Master - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=319&maincat_no=1
Regards
Mike
Mar 27, 2008 | MSI MS-6163 Pro Motherboard
Audio and video track are not in sync
I guess that your CDROM Device doesn't have DMA (Direct Memory Access) enabled.
From the Microsoft Knowledge Base Article:
To enable DMA mode using the Device Manager
1.
Open Device Manager.
2.
Double-click IDE ATA/ATAPI Controllers to display the list of controllers and channels.
3.
Right-click the icon for the channel to which the device is connected, select Properties, and then click the Advanced Settings tab.
4.
In the Current Transfer Mode drop-down box, select DMA if Available if the current setting is "PIO Only."
If the drop-down box already shows "DMA if Available" but the current transfer mode is PIO, then the user must toggle the settings. That is:
Change the selection from "DMA if available" to PIO only, and click OK.
Then repeat the steps above to change the selection to DMA if Available.
Oct 14, 2007 | Computers & Internet
Intel D101GGC Motherboard Logo
90 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
