? 4:20
https://www.youtube.com/watch?v=o6UfFwsW3J8
Sep 26, 2010 - Uploaded by Whirlpool Appliance Repair Self Help Videos
Proper installation, method, and location of drain hose ... ... How to: ensure your washing machine or dishwasher drain pipe is connected ... How to Hook Up Washing Machine Plumbing - This Old House - Duration: 4:12. by ...
The exact list of parts for a dishwasher hook-up would depend on the existing plumbing and electrical . There are three hook-ups needed; a hot water feed, typically from under the sink. A Tee is installed on the hot water line with a valve, and the hot water line to the dishwasher is connected to the valve. A drain line from the dishwasher is installed under the sink. It connects to the sink drain. The Electrical connection can be made using the appropriate electrical cord.
There are specific guidelines and considerations on how to connect the drain line under the sink, and what is required for the electrical hook-up. If you do a search on "how to install a dishwasher" you will be able to find extensive information.
Try cleaning drain with a length of wire. Strip insulation back about an inch. Turn exposed wire back to form a hook and put down drain and spin, then remove from drain, repeat until hook comes out fairly
clean. Then put drain cleaner down drain, follow instructions with drain cleaner. This should remove gunk that is preventing stopper from working correctly.
Is sink drain line clogged? Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains. Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
If it is brand new, there is a plate that needs to get knocked out of the disposal where the drain hooks up. Remove this metal plate, hook up the drain and away you go. Unless you forgot to hook up the air gap, that may be causing you to have a vacuum effect which will not allow the water to go down, or lastly, you may have a clogged drain past the disposal which you may need to snake out first.
It is better to have it hooked to its own drain with a airgap. Hooking it up to the disposal can create a cross connection with the potable water supply.
