Power went out on tv want to know where fuse is located its a dynex 37 lcd tv two years old
  • 5,568 Answers
Sorry to tell you this but your problem is probably not a blown fuse. All later sets are using a much more efficient but less reliable type of power supply called a 'switched mode power supply.' If only the best components of a certain type are used they are reliable and even with cheap parts, PC supplies use this principle and can live quite long. I'll paste below some things you can do:
The assembly that most affects these audio and video equally is the power supply and this is a common failure in all too many of more recently built TVs.
The supply is normally built on a separate board since these are often out-sourced by set manufacturers.
Unplug your set overnight to allow potentially hazardous voltages to discharge, remove the back panel of the set so you can see the guts.
Look for a smaller board with larger parts on it; some cylindrical (capacitors), others block-like and relatively large (chokes and transformers).
You should also see a relationship between the board and the incoming AC.
Check the board for a label or if not present, a stamped-on number.
Call the manufacturer's service center with your TV model number and the number found on that board and inquire about repair/replacement costs; if both are offered, they won't be that much different.
If you must buy a new board, don't dispose of the failed one as there are smaller companies that can repair it for less than the mfr. and then keep it as a spare as this problem will likely arise again.
Good luck-
Posted on Oct 04, 2009
Dynex 37" LCD won't power on
You may either poor 24vdc power supply problem or failing backlight inverter board, you need to check the voltages before and after the set acts up.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find
Jul 24, 2010 | Dynex DX-LCD37 TV
Olevia tv, no power
This the common problem for Olevia TV, open up the back cover, locate the power supply board, look for the electolytic capacitors top that is slightly domed, replace them, they usually 1 or 4 that is bad, buy your replacement's at Radio Shack
Jun 06, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Dynex 37" LCD TV bad color
You have a bad LCD control board going bad,Color getting floresent? Or pixely? esp. when you have it on for a bit. Common prop. But finding parts is a prob.
They are no longer in buis. Try Shop Jimmy,or even Ebay. Encompass does not have any. Runs about 40-60.
Oct 26, 2009 | Dynex DX-LCD37 TV
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Dynex 37'' LCD TV (DX-LCD37-09) wont turn on
The registration card may help with warranty going through the TV company. But, that's the last option.
You can fix it yourself by replacing this board. The board number should be BA71G0F01043.
The 8 Inverter transformer are the problem. They are on many TV power boards that are causing the same problems.
Ebay is selling a couple for $49. Good price I think.
http://www.google.com/products?sourceid=navclient&rlz=1T4GGLL_enUS311US314&q=dx-lcd37-09+inverter&um=1&ie=UTF-8&ei=oRf9SYKIG5_aswOMoPTjAQ&sa=X&oi=product_result_group&resnum=1&ct=title
If you decied to throw the board in the trash, let me know. I maybe able to help you fix it so you can have a spare board. I fixed mine that way.
May 03, 2009 | Televison & Video
No power to my tv dynex 37 lcd
check the fuses in the plug and the on board fuse in the set
Apr 30, 2009 | Televison & Video
TV problem
The power supply is defective on your LCD and will need to b e replace or repair to the component level.
Service parts seem to be a bit hard to locate now a days.
You can write to jah2mil@hotmail.com for more info.
Aug 14, 2008 | Protron PLTV-37 37 in. LCD Television
No sound on LCD tv
in the audio part of the menu, check to make sure the internal speakers are not turned off.
what connection are you using for the DVD? if using YPrPb, make sure you also have the audio red and white plugged in
Feb 12, 2008 | RCA L37WD12 37 in. LCD HDTV
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
Electro Med Services...
