Question about Canon PowerShot A95 Digital Camera
What is a "memory disc" error message?
I have a "memory disk" error
    Brigadier General:
  • 11,967 Answers
A memory disc is the memory card...it needs to be formatted in the camera in order to work properly.
Posted on Oct 04, 2009
Trying to reload Windows OS. Run into
From another computer build a msdos floppy disc, yes floppy disc.
I believe you computer accepts floppys does it not? and i also asume you are running xp, you can try running the startup disc and trying to check disc, but if you cannont procede, i would opt into downloading another copy of the windows and try installing through that method. If the disc dosent load, and you get that error message of the bat, another step will be waiting for you.
May 26, 2012 | Dell Dimension 8400 PC Desktop
MY LAPTOP GOES TO THIS BLUE SCREEN THEN SHUTS DOWN WHY DOES IT DO THIS
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 14, 2012 | Toshiba Computers & Internet
I have the same problem the toshiba recovery disk i get error message 10f8060017.its a toshiba A105-2194 win xp media edition. i have tried everything wiped the disk to all 0's. Used a win xp original disc...
You have tried all possible solutions and troubleshooting.
My Suggestion is to check the Warranty of the Hard Disk and get it replaced. this possible shows a mismatch between the Laptop and hard drive.
Feb 15, 2011 | Toshiba Satellite A105 Notebook
My x box wont read any discs
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/816779
Note 1 If a saved game file is corrupted, it can produce a disc error message in that game, particularly when the game starts. You can resolve this issue by deleting all saved game files for the affected game from the Xbox hard disk. This method is effective approximately twenty-five percent of the time. If you experience this disc error message with more than two games, this procedure will likely not resolve the issue.
Note 2 Do not use laser lens cleaners, or similar products. Microsoft has not determined the effectiveness of these products or the affect they may have on the Xbox system. Microsoft cannot promote or recommend any type of laser lens cleaner for use with the Xbox system.
1. Clean the disc and examine the disc for flaws or scratches
Hold disc by the edges without touching the surface with your fingers.
2. Clean the disc with a soft, clean cloth, lightly wiping from the center outwards.
3. Do not use solvents or chemicals to clean the disc.
4. After you clean the disc, examine the disc for any scratches or defects. If you find any defects that are not caused by typical wear and tear, return the disc to the retailer if it still under warranty.
Copy and delete any saved games from your hard disk
Note To copy saved games, you must have an Xbox Memory Unit (MU). You must copy saved games to a MU before you delete them.
1. Start your Xbox console with no disc in the disc tray. The Xbox Dashboard appears.
2. On the Main Menu screen, press the directional pad (D-pad) up or down to select Memory, and then press the A button.
3. On the Memory screen, press the D-pad up or down to select Xbox Hard Disk, and then press the A button.
4. On the Xbox Hard Disk screen, press the D-pad up or down to select the game title you want, and then press the D-pad left or right to select the saved game you want to copy.
5. On the Copy/Delete screen, press the D-pad up or down to select Copy, and then press the A button.
6. On the Copy To screen, press the D-pad up or down to select the memory unit you want to copy to, and then press the A button.
7.Press the B button to return to the games list on the Xbox Hard Disk screen.
8. On the Xbox Hard Disk screen, press the D-pad up or down to select the game title you just copied a saved game from, and then press the A button.
9. On the Copy/Delete screen, press the D-pad up or down to select Delete, and then press the A button. You receive the following message:
Are you sure you want to permanently delete this saved game?
10. Press the D-pad left or right to select Yes.
11. Repeat these steps for each saved game on the Xbox hard disk. If you have many saved games but you can remember when you started to receive the disc error message, you can just delete the saved game files that you created after that time.
Back to the top
Please let me know if you have any issues.
Regards,
Feb 11, 2010 | Microsoft Xbox 360 Console
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
I get a "cant read disk" screen on my xbox
# Turn console off and then on. # Clean the disc and examine it for flaws or scratches. # If this behavior occurs with one or two discs, search the Microsoft Knowledge Base for the specific game title(s). If you find a known problem, follow the information outlined in the article. # Delete the appropriate saved games. See Note 1. Copy a saved game to a Memory Unit (MU) if you have one available. # Try three other games, and then try the original game again. # Try the game on another console if possible. # Replace the disc at retailer. # Repair the console Note 1 If a saved game file is corrupted, it can produce a disk error message in that game, particularly when the game starts. You can resolve this issue by deleting all saved game files for the affected game from the Xbox hard disk. This method is effective approximately twenty-five percent of the time. If you experience this disk error message with more than two games, this procedure will likely not resolve the issue. Another trick to try is to turn your console so its vertical( sometimes works)
May 17, 2009 | Microsoft Xbox Console
Recovery Error
Do recovery again, when it asks you to insert disc 2, take out disc one and close the tray. Do not put the disc 2 yet. If you can see the error message again, then it is a RAM issue. You need to reseat the Memory module and try to do the recovery again.
If you closed the tray then no error message came up, it would be an issue with your recovery disc and order for a new one. You can contact Toshiba to have the recovery replaced due to corrupt media.
Hope this helps.
Sep 12, 2008 | Toshiba Satellite A105 Notebook
To install wii fit
    "Unable to read the disc" / "Disc could not be read" / "Eject the Game Disc" Error Message.
    If you are getting one of the above error messages:
    • If your console is placed vertically, the disc label will face to the right.
    • If your console is placed horizontally, the disc label will face upwards
  • If you know you are inserting the Game Disc correctly, but are still have the same problem with only one game (or if you only have one game), try cleaning the Game Disc by following the disc cleaning procedures
  • If after reading the above information you are still unable to play a game disc, please call 1-800-255-3700 to discuss available options.
Aug 13, 2008 | Nintendo Wii Console
D2P.exe Common Language Runtime Debugging Services error message
you dont need disk to phone connect usb and go to my computer select memory disk -mssemc -media files-audio and save mp3 there its much faster and easier than disk 2 phone
Jan 12, 2008 | Sony Ericsson W200i Cellular Phone
Camera wont take a disc
hi NanaR, i suggest a try with new disc,problem still remain, i think there is a mechanical problem with disc holder. I suppose you have the facility to use memory stick so why you use the disc just use the memory stick. It is better for you. to fix the problem you have to go to sony shop.. good luck...
Jul 28, 2006 | Sony Mavica MVC-FD75 Digital Camera
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
