Question about FIC FR 33E (CI-FR33E) Motherboard
I need connection diyagrams exp where i put harddisk power ,reset cable vs vs
Extenal hard disc when plug in the USB the PC can't read
You may need to plug in an additional cable for power for the hard drive. If you have, make sure the hard drive itself is not broken
Mar 01, 2011 | Seagate Computers & Internet
Hard drive not detected what can i do
If your hard drive is not being detected the moment you startup the computer, then try to turn it off and open the computer's casing. Pull the two cables connecting to your hard disk and wait for like 5 minutes before plugging the cables back to it. Then power it back and see if it gets detected. If not, then your harddisk might have failed. You might want to check it though thru the CMOS setup if the Seagate disk drive is still on the list of the Boot devices. If not, then you can do a data recovery by unmounting the harddisk from your computer and put it as a slave drive to another computer or to an external harddisk usb enclosure.
Should you need further assitance, please let me know. Thank you for using FixYa.
Dec 16, 2010 | Seagate Computers & Internet
New extra harddisk
u need to make the first hard disk as master and second one as slave..
reset he jumper as shown in the face of harddisk
connect it with the cables and power supply
manage bios
restart
Mar 10, 2010 | Computers & Internet
It wont rocognise the hard disk but will pick up everything eslse
Change ide or sata cable.
Also change power cable of smps to harddisk.
Make sure your harddisk set as master with jumper settings.
Read jumper settings on harddisk then set harddisk as master.
Then check in bios.
Change ide or sata ports on motherbord then check.
Nov 17, 2009 | EliteGroup K7S5A Pro Motherboard
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Sep 19, 2009 | Dell Precision T3400 375W 32bit Computer...
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
Es2 300x not boot up
Open your cpu cabinet.
Refix your RAM clean all dust from circuit bord.
Reconnect power cable and ide or sata cable to harddisk.
Reconnect processor fan and processor.
Reconnect power supply from psu to motherbord.
Pull your cmos cell from motherbord for 15 minutes from motherbord so all settings are reset to defaults.
Check in bios your harddisk is detected?
For boot your computer with operating system your harddisk must detect in bios.
Aug 15, 2009 | Computers & Internet
I cant get my pc to boot
Aug 03, 2009 | Office Equipment & Supplies
My 160gb and 500gb are not showing on the desk top last night they were there. I hasve done all the simple trouble shooting turning htrem off and on, unpluging the power and firewire cords and rebooting...
Hi Bob,
Just try resetting the BIOS and check if it works.
You need to access BIOS screen and most of the computers has F% key is assigned for Loading the Dedault Settings. After F5 key you need to press the F10 key to save the settings and exit from the BIOS.
Hope this helps!
Pat
Mar 14, 2008 | Computers & Internet
FIC FR 33E (CI-FR33E) Motherboard Logo
19 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
