Question about GE Ovens
Gerangeoven door won't open
Oven door won't open
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 04, 2009
    Problem Solver:
  • 7 Answers
Is it in time bake?
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
AFTER SELF CLEANING DOOR WON T OPEN AND CONTROL NO POWER
Is this a whirlpool product wall oven or free standing if so you will need to get door open to provide a model number then I can tell you If it has a thermal cavity fuse most models you can slide a flexible piece of plastic between oven top and latch and push to left to get door open keep me posted
Feb 16, 2015 | Ovens
Frigidaire door lock won't reset
Hello Steven Krenz - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Apr 02, 2013 | Frigidaire GLEB27S7A Electric Single Oven
Oven door won't stay closed, light on
If the door opens past the 90 degree level position, it means you need new door hinges.
Mar 06, 2013 | Thermador SM272 Electric Double Oven
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Ovens Logo
312 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
