Question about Toshiba Televison & Video
I have a 1 inch line at the top of screen, does this mean it s going out or can it be adjusted or repaired
  • 647 Answers
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Oct 04, 2009
I have a Philips TV model: 27pt9015d. at the top of the screen several horizontal lines have appeared. it looks like the top inch is being cut off and then flipped back. that is - when credits are...
sounds like the vertical adjustment has spanned beyond the screen, causing it to jump up and then upside down. after the cover is removed look for vertical adjustment and with a non-conductive screwdriver, adjust it a little bit either way to see if it fixes it, if it doesn't fix it, then look again for the right one.
Jun 18, 2008 | Philips Televison & Video
It's a Sony 32 inch flat screen led tv. Has line going across screen about 4 inches from top and faded verticals lines across tv. Anyway to fix that
one of the circuit board needs repairing replacing. I wouldn't recommend trying it yourself even though it wont be too difficult but without electronics knowledge you could end up getting the wrong parts and wasting good money. Parts aren't cheap so get a quote from a repair guy and prepare to replace the TV if it's dear
Jan 11, 2013 | Televison & Video
55 inch hitachi plasma
Try re-seating your upper and lower buffer board connectors. These boards run the length of the set on top and bottom. Since your line is from the top going down I would check that one. The connector will be close to where the line is showing up on the screen.
Jun 18, 2009 | Hitachi 55PD8800 55 in. Plasma Television
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
How to adjust white lines on screen
it depends, sometimes this problem is caused by a capacitor around the crt socket or around the flyback and horizontal out.
or sometimes the signal reciever section..
Jan 27, 2008 | Televison & Video
1 inch lines on top and bottom of screen
Is the picture overall too small by 1 in. on top and bottom? Or is it cut off by the lines?
If it's too small, look for an adjustment labeled Vertical Height. This may only be accessible internally, it's normally a service adjustment, not a user adjustment.
Your problem is a vertical deflection issue, either an adjustment or the vertical circuit requires repair by a technician. In the latter case, electrolytic capacitors are a likely cause.
Oct 17, 2007 | Televison & Video
Sounds like there is a problem in the convergence circuit. There should be an on board cross hatch and controls to adjust the lines to a white line. If these control wont adjust then the power ICs in the convergence circuit are most likly bad. if you know how to solder and know how to replace electronic parts then get a service manual find the part #s and order the parts . If you dont know how I can teach you here sorry. But I will tell you that a repair like this will run about 300 to 400 bucks to repair. Good Luck
Jun 04, 2006 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
