Question about Microsoft Outlook Express
Unable to move Outlook Express 6 email files to my new PC
I am unable to move Outlook Express 6 email files from my Compaq (running XP) to my new Asus PC (running Vista). I am using the MS procedure for manually copying them and can sucessfully paste the OE folder in the new PC, but when I use the Import command and get to the step asking me to click on the folder I want to import, I see the error message ''No items match your search.'' Apparently it does not recognize the file folder name as legitimate.
OE runs just fine on the old PC, even though I renamed the mail folder some time ago in order to remove the Windows User Identity Number from it. I did that in an attempt to solve a problem when I thought I had lost all my email files. Seemed to have no ill effects on my email operation since then. I have no idea how to recover that ID number if it turns out to be the cause, but I do need to move these mailbox files to my new PC.
Thanks for your help,
Don
    Habit-Forming:
  • 47 Answers
This may be a mickey mouse solution but it may work.
On the vista machine go on internet and create a free web based email account(gmail,hotmail...etc)
From the old machine forward those emails to you web email account.
From your web based email account mail them to your pop3 account(outlook express address)
Posted on Oct 05, 2009
Testimonial: "That is an ingenious solution. I'll give it a try. Thanks much. Don"
Can't send emails in Outlook Express
Save yourself alot of headaches and use a web-mail service like Gmail.
Oct 27, 2014 | Microsoft Outlook Express
Unable to retrieve email
RecoveryFix for Outlook Express recovery software is capable of recovering every item from damaged Outlook Express files. This software supports all Outlook Express version like 4.0, 5.0, 5.5 and 6.0. To know more see here: http://www.en.dbxrecovery.net and also visit this this blog post http://recoveroutlookexpress.blogspot.com
Nov 29, 2013 | Microsoft Outlook Express
I wish to download windows outlook express to my new computer. I would like to transfer all the data including email addresses from my office PC onto this new Toshiba laptop
  1. Open Outlook Explorer.
  2. Right-click on the Folder at the top of the left pane, and, from the context menu that appears, select Properties (see Figure 1 below). If you are using Outlook 6, you need to expand the Folders and right-click on the Inbox (see Figure 2 below).
  3. When you select the Properties option, you are presented with a dialog box with the location of the Outlook folders (see Figure 3 below). The full path is displayed as a label in Outlook 6 and as a text box under the Advanced tab in Outlook XP or 2000.
  4. Select the entire path from "C:\" to "\Outlook Express". Do not copy the filename given after "\Outlook Express." For example, if the path is C:\Documents and Settings\USER\Local Settings\Application Data\Identities\{B7ABE5FE}\Microsoft\Outlook Express\Inbox.dbx, you need only the C:\Documents and Settings\Arun\Local Settings\Application Data\Identities\{B7ABE5FE}\Microsoft\Outlook Express.
  5. Copy, paste, and save this path in a text file.
  6. Open a Windows Explorer window, and paste the path into the address bar and press Enter.
  7. Before proceeding to copy the folders to a CD or flash drive, you need to check if there are any hidden files or folders in the Outlook Express folder. To check this, check the Show Hidden Files and Folders in the View tab of the dialog box that you get when you select Folder Options in the Tools menu.
  8. The next step is to select all the files and folders in the Outlook folder. If you are using a version previous to Windows XP, you will need some CD burning software to copy the files to the CD. Otherwise, you can simply paste the files to the CD or flash drive. Do not forget to copy the text file containing the path in both cases.
  9. You now have all the emails, calendars, tasks, and other important things from Outlook, but you may also want to copy the address book. To copy the address book, use the Export option in the File menu of the Outlook Express. Once exported, use the method described above to copy it to the flash drive or to the CD. Now you are all set to move your Outlook messages to the new computer.
  10. Boot the new computer. Use the path you stored in the text file to open the Outlook Folder on the new computer. To do this, copy the path from the text file, open a Windows Explorer window, paste the path into the address bar, and hit Enter.
  11. Copy all the files from the CD or flash drive to the Outlook Express folder. When you are prompted to overwrite the files and folders, select Yes to All.
Read more: http://www.brighthub.com/computing/windows-platform/articles/45168.aspx#ixzz1FV6xRlBl
Mar 03, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Microsoft Outlook
If you attempt to send a message that is too large for your mail server you may be unable to delete it from the Outbox.
First, try setting Outlook offline using the File, Offline menu. Wait about a minute or so or close Outlook and reopen.
If you are unable to delete the message while in offline mode or cannot go into offline mode, you'll need to change your default delivery location.
  1. Add a new PST using the File, New, Outlook Data File menu.
  2. Open the Email Accounts dialog on the Tools menu.
  3. Select view or Change existing email accounts and click Next.
  4. Select the new personal folders file from the Deliver new email to the following location list.
  5. Click Finish and restart Outlook.
  6. Show the folder list, using Ctrl+6 if necessary, and find the old Outbox. Delete the message.
  7. Repeat steps 2, 3, 4, and 5 to restore the original pst as the default delivery location.
  8. Show the folder list and move any new messages from the new pst to the original pst.
  9. Right click on the new folder's name and Choose Close to remove it from your profile.
May 05, 2010 | Microsoft Windows XP Home Edition
I canot delete emails from outlook espress
move all othe emails from the in box to a temporary folder, closing outlook express and then going to my computer- c drive - documents and settings - (my) user - local settings (which is a system folder)- application data - Idenities - Microsoft - Outlook express. in this folder are all of the .dbx folders. Delete the inbox.dbx folder. Open Outlook express it will automaticly make a new Inbox folder and you can move the other messages back in.
Nov 05, 2009 | Compaq Presario C700T Notebook
Unable to send emails in outlook express...the scree is blue and unable to type in the same
check the setup in outlook which you have to choose between option of your choice.
Oct 09, 2009 | Compaq Presario 5000 PC Desktop
Outbox - Outlook Express 6
Hello
I havent seen that problem with Outlook Express just with Microsoft Outlook. but this solution should work with outlook express to.
here how you solv it. you need to remove the outbox file manually. remember that all your outbox files gonna be deleted.
step by step.
1.close outlook express
2. go to C:\Documents and Settings\"your user name"\Local Settings\Application Data\Identities\("alot of numbers here.->"{7850C6E6-099E-4EFD-A3F5-A88CA4FC6169}\Microsoft\Outlook Express\
* if you can find Local settings you need to show hidden files!
a. go to tools>folder options->view-> mark show hidden files and folders-> ok
3.in the map outlook express delete the outbox.dbx or move it somewhere.
4. try now to start the outlook express and the outbox should be empty.
good luck.
Sep 04, 2008 | DBX -215 Home Equalizer
OUTLOOK EXPRESS BACKUP FILE
BAK and BK files usually are backups of other documents or files.
The BAK (or BK) file extension normally represents files that are backup copies of other file. There is no 'standard' file format for BAK files. BAK files can represent virtually anything.
This link will take you to an on-line storage of software I have. Download and run easyrecovery pro. Select E-Mail repair. Select Outlook express.
Mar 27, 2008 | Computers & Internet
Unable to send email more than 3mb by outlook express
there will be a restriction in your office , restriction can be made in exchange server
Mar 25, 2008 | Microsoft Windows XP Professional With...
Microsoft Outlook Express Logo
137 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
