Question about Measuring Tools & Sensors
I have a honda 3000is generator. It has been in a damp environment, now is locked up. I can not pull the starting cord and a charged battery will not turn it over.
  • 148 Answers
If you don't wish to tear into it just yet, you might try removing the spark plug and soaking the cylinder with penetrating spray.
Be patient and treat it several times. DO NOT try to start it when it frees up. The penetrating oil will have the engine oil contaminated, so do an oil change after it is free and then try to start it.
Also, don't assume that the engine is the source of the problem. If the inverter is oxidized it can have the same effect. Same treatment might free it up on that end of the machine.
Hope this helps.
Posted on Oct 05, 2009
My Honda generator 3000is when hot,does not start with key,the battery is new,the spark plug too, it only start with hand crank
Does it have a pre-engaged starter motor, that is the solenoid is fitted directly onto the starter. Check for voltage drop off across the two main cable connections on the solenoid. If faulty clean contacts or replace the solenoid.
Dec 01, 2017 | Honda Cars & Trucks
Why can't i run my a/c with honda 3000is generator
This generator will run an a/c unit up to 13500 btus and is good for 2800 watts. This is a small generator, the nameplate rating numbers need to jive before overloading the energy supply.
Jun 03, 2017 | Honda Electrical Supplies
13,500 a/c blows circuit and won't run off our honda 3000is generator
will it blow any circuit? if so, the a/c has an electric problem. will the a/c run when plugged into a
service power supply?
Honda 3000is repair manual
http://www.geotechenv.com/Manuals/Honda_Manuals/EU3000is.pdf
Dec 19, 2013 | Honda Eu3000is Eu3000 Generator Service...
Honda EU 3000is only runs on half choke
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
May 04, 2013 | Honda EU3000iS Inverter Generator
I have a Honda 3000IS generator that only produces ~50 volts from the 30A receptacle--the other receptacles work fine, as does everything else on the machine. How do I get full voltage out of this...
I would guess that this uses both of the 15 amp breakers to make the 30 amp circuit. Try carefully measuring the voltage at the back of the 30 amp outlet after pulling it out. You may have a bad socket. look at how it's wired behind the panel too and see if there are wires from the other sockets to this one. If so, check all connections between them. If you still can't figure it out, try to get a picture of the panel and the wiring behind it and send it to Shelomah@i-can-fix-that.com
Dec 06, 2009 | Honda 3000 Watt Portable Generator
I have a 3000is not starting. Has gas spark oil.
Use fresh gas! Dont just pour some on top of the old...Change it out.
Drain the carb bowl (Honda carbs have a drain screw slightly off-center of the bowl bottom).
The Honda EU3000is uses a vaccuum-operated fuel pump and old gas will ruin it also.
Take the fuel supply line off the carb inlet, direct it in a container and spin the engine over. It should pump a stream that is FULL LINE DIAMETER.
If still no start, take it to an AUTHORIZED Honda Power Equipment Dealership.
Find one here.
Hope this helps.
Sep 27, 2009 | Honda 3000 Watt Portable Generator
Battery in a honda 3000is
The battery is behind one of the end plastic casing pieces. You have to remove the center plastic panel, then remove the bolts holding the handle in place, and then remove the small, lower metal panel. I don't remember if it is on the side where the exhaust opening is or not, I believe it is on that same side.
May 04, 2009 | Honda 3000 Watt Portable Generator
My trace inverter SW2512 will only allow pass through power.
First problem is caused by the new generator producing too high a frequency... 65 Hertz is above the inverter limit. Adjust the governor down to 60 or 61 Hertz.
Breaker tripping may be due to excessive current draw from the Honda. Check the max AC input menu on the inverter. It might have been set lower to avoid overloading the original generator but if DC power was turned off at any time while you were changing generators, the inverter would have returned to it's default settings which may exceed the Honda's capacity.
Mar 29, 2009 | Xantrex Technology Trace Series Inverter /...
Need a battery for honda eu3000is
New battery for Honda eu3000is can be found on amazon. take a look here Charge your devices with guaranteed safety and chose the best one. P.S. watch out on seller reviews. I hope this was helpful. cheers
Mar 28, 2009 | Honda 3000 Watt Portable Generator
Measuring Tools & Sensors Logo
144 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
