Question about Whirlpool Freezers
4 yr. old side by side not cooling on either side. Fan running but compresser is very hot.Could it be low on freon? Thanks Tim
    Problem Solver:
  • 7 Answers
They NEVER go low on freon unless you have a leak. If so it must be found and repaired. I would recommend calling a qualified technican to service your unit.
Posted on Oct 04, 2009
Whirlpool freezer cool air but not freezing?
Check the seal first. Then check the freon. If it's R-12, you can go to the auto parts house. They have a bottle with a hose to add freon. You put it in on the "suction" low side with the unit running. you can tell when it has enough by feeling the low line be cold and teh high pressure line is warm to hot
Jun 06, 2014 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
This is a second hand freezer purchase. When starting it for the first time, it cooled rather quickly inside but the sides and top became very hot to touch and we unplugged it. Is this a dangerous problem?...
Usually the frame getting hot is a sign that either the condenser grill is dirty or blocked or not getting enough air flow around it; or the condenser fan is not working or maybe even the compressor being low on freon.
I would suggest you start with a thorough cleaning, then check the fan and make sure it is working.
Since you said it cooled down quickly, I wouldn't think it was the compressor freon level. More likely dirty condenser grill or where you put it. I have might on 4" x 4" to get it off the ground for better air flow and ease of cleaning. It must work because I have had it since 1983 and never had to do more than clean the grill on it.
Jul 01, 2011 | Frigidaire Freezers
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Panel is hot and freezer does not work!
Check the condenser fan underneath the unit accessable form the back behind the cardboard cover. It should be running when the compressor runs. OR Check the evaporator behind the rear cover inside the freezer. Check for ice build up. . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Sep 09, 2009 | Freezers
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Left outside is very warm & inside products are thawing, what can be wrong?
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Mar 03, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Whirlpool sbs fridge freezer - freezer stopped working
Feb 24, 2009 | Freezers
Freezer stopped freezing
If you checked the fan and for ice on the back wall (for defrost problem) Then you most likely are low on freon or you have a bad compressor. Check to see if the compressor is running (IF scorching hot its bad too) . Next check to see if the coils under the unit are hot. They should be so hot you cant hold onto them. Just touch for a second. If they are just warm, then you are low in freon.
Nov 19, 2008 | Freezers
Freezers Logo
51 people viewed this question
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
