Question about Hitachi 51S500 51" Rear Projection HDTV-Ready Television
What is the replacement lamp part # for a Hitachi Rear Projection 51S500
  • Hitachi Master
  • 5,138 Answers
You have 3 Tubes RED/GREEN/BLUE you do not have a Lamp your TV is projection not DLP Go to Encompass Electronics.com 1-800-638-3328 they have a list of all parts to your TV.
Posted on Oct 04, 2009
Hitachi 51s500 screen is flashing, but no real picture or sound, where is the master reset button?
this set has no reset button at all. If the screen is flashing is it red,green, blue, 3d or what? This may be a clue to what is wrong.
May 05, 2012 | Hitachi 51S500 51" Rear Projection...
Keep losing picture on my hitachi hd channels only. when i put it on antenna mode, we have a picture. can u help???
You need to change the output format from 1080i to 720p or 480p in your cable box. this set may no support 1080i.
Dec 18, 2010 | Hitachi 51S500 51" Rear Projection...
No red color
Check the CRT board on the back of your Red CRT Tube check to see if the driver chip is bad. Most likely you will need to have a tech replace your red CRT.
Aug 14, 2010 | Hitachi 51S500 51" Rear Projection...
MY HITICHI 51S500 WONT PASS BLUE ON MAGIC FOCUSIS IT WORTH IT TO FIX
In most cases the convergence IC's will need to be replaced and the alignment touched up. This is not really a labor intensive repair for a technician to perform at all. I would say see if you can get an estimate for a minimal amount or free if the shop does so then make your decisions from there. Mind you to look at the cost to replace the TV and the fact that TV's today will run more efficiently on electricity. Please take a moment to rate my answer. Thanks....
Dec 02, 2009 | Hitachi 51S500 51" Rear Projection...
My Hitachi 51S500 is showing a black screen
Did you unplug the set from the wall and wait 5 min. replug and try. Cusult your owner manual regarding parental Locks?
Sep 17, 2009 | Hitachi 51S500 51" Rear Projection...
No picture and no sound
revise la etapa de la comvergencia que los ic tienen que esta an corto
Aug 22, 2009 | Hitachi 51S500 51" Rear Projection...
Hitachi 51S500 51 in.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Aug 11, 2008 | Hitachi 51S500 51" Rear Projection...
Hitachi 51S500
check out ctechnicians.com and ask if its the pink screen?
Dec 25, 2007 | Hitachi 51S500 51" Rear Projection...
BROKEN SCREEN
Order one from Vance Baldwin Electronics at www.vancebaldwin.com.
Dec 21, 2007 | Hitachi 51S500 51" Rear Projection...
Hitachi 51S500 51" Rear Projection HDTV-Ready Television Logo
258 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
