Question about HP LaserJet 1300 Printer
The paper wrinkles up while going through
The printer is an HP 1300 and the paper wrinkles up while going through on the left side as you face the printer.
  • 81 Answers
This is possibly down to the upper fuser roller wearing and catching the paper when it goes through the fuser. The upper roller surface breaks up and splits
Posted on Oct 13, 2009
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Hp 1300 Prints fine but creates a slight wrinkle afterwards on the top left corner of each page. I have blasted the insides of the printer with compressed air whihc made a slight difference.
This could be due to either dust inside the roller shutter or due to paper block which is torn and stuck. I suggest you to get the printer serviced by a near bye service centre.
Good luck.
Oct 19, 2010 | HP LaserJet 1300 Printer
Printer prints but crumples paper
I guess you have a roblem in your fuer assembly, replace it
Apr 07, 2010 | HP LaserJet 1300 Printer
Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Apr 03, 2010 | HP LaserJet 1300 Printer
Paper wrinkles on one side when comes out of printer
hi i have printing problem when i was gave print after output on print right hand side in some lines in black form contiuos print on paper.
Jan 31, 2010 | HP LaserJet 1300 Printer
Paper comes out wrinkled & dark on one side
Your fuser is worn out. It can be replaced as an assembly, but sadly it is actually less expensive to replace the printer these days.
The wrinkling is due to a worn pressure roller, and the darkness is from the combination of a worn fuser sleeve, and the worn pressure roller 9all located within the fuser)
Jul 10, 2009 | HP LaserJet 1300 Printer
Paper wrinkles on left side when printing
Fuser is worn out (specifically, the pressure roller).
May 19, 2009 | HP LaserJet 1300 Printer
HP 1300 makes noise and wrinkles paper
open the back door. see if there are small Pisces of plastic the color will brown or gray. if there is then the fuser sleeve has worn out. very common problem. part is a bout $40.00.
Dec 18, 2008 | HP LaserJet 1300 Printer
Paper completely wrinkled
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
Jan 19, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
350 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
