Question about Kenmore Dryers
I have a kenmore 27 inch electric dryer that when you push the start button it sounds like it starts but the drum doesn't turn. What could this be?
    Problem Solver:
  • 18 Answers
A clear indication that your dryer belt is broken is when the dryer drive motor runs but the drum does not rotate. A new belt is relatively inexpensive from several online or a local parts vendor, but installing it can be a bit frustrating since the dryer drum usually needs to be remove to install a replacement belt. Access to the interior of the dryer is usually necessary. For Maytag (and some Kenmore) models, the front of the dryer can be easily removed (two screws below front contour) by pulling out on the bottom of the panel and rotating up to release the top clips. Once off, place to the side, then remove four machine screws from the front drum/lint filter assembly, then remove by pullling out. Once off, place aside. Remove drum by lifting up and pulling out on drum (since the belt is broken it will not provide any resistance). Once removed, inspect the motor pulley arrangement noting the belt routing path around the motor pulley, belt tensioner, and the drum. Inspect the drum for belt wear marks, noting approximate location on drum where belt rides. Install replacement belt by routing through pulley arrangement (ridged side of belt rides againt motor pulley), then "hang" the belt on the interior backside to enable reaching the belt after reinstalling the drum. After placing the drum edge on the rear rollers, lift the front of the drum up into position, working the belt around the drum into the drum groove. Once the belt is in the groove, the drum should stay in position without lifting from the front. Check for proper pulley routing, taking care to avoid routing the belt OVER the tensioner belt keeper, i.e., route the the belt under the belt keeper to avoid belt riding on the keeper and failing prematurely. Install the front/lint filter assembly. As you manually rotate the drum, reach along the top and side of the drum and gently pull the belt out of the groove and into its normal ride position. Install the front panel, plug the unit in, start and check for proper rotation of the drum.
Posted on Oct 04, 2009
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
I have a Kenmore 600 electric dryer. The basement flooded and the dryer was in approximately 6 inches of water. I've removed all the water from the cabinet and let it sit for 2 days to completely dry out....
Sorry to say but water ruined the motor. You can test it again by pushing the start button and at the same time spin the motor. If the motor starts that will tell you the start windings in the motor are bad. The motor would have to be replaced.
Mar 20, 2010 | Kenmore 63942 Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore elite 110.63032101 dryer has electric, start button seams to be working, but pushing door button and turning drum still won't start it?
is the motor humming or did you start it like this before by spinning the drum,if so you have a bad motor,also is the door switch making a clicking sound when you push it in and out,it should if it doesn't you could have a bad door switch,read it out with a meter and make sure you have power to the motor,
Feb 20, 2010 | Kenmore Dryers
My dryer drum will no longer turn easily...and dryer won't start.
sounds like the motor is going bad,did you remove the top to see if the belt broke or if it jumped the track?mike
Feb 19, 2010 | Kenmore 62802 Electric Dryer
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Dryer won't start when pushing the button it clicks
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
Jan 14, 2009 | Kenmore 62602 Electric Dryer
Kenmore 27 inch wide electric dryer
Can you turn drum by hand? If so you probably need a motor.
Nov 19, 2007 | Dryers
Dryers Logo
251 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
