Question about Adaptec (1913500) USB2Connect 3100LP 760884138106 (adap1913500)
Toshiba HD tape drivers installing failed
Harddisk is a toshiba! its showing The installation failure of tape drivers after it fell off frm ma hand....... he;p me out please!!! i dont want to loose the datas inside.
    Problem Solver:
  • 11 Answers
I have a problem with my external hard drive. it is failing to install drivers on the pc
1st question is: does it work on any other computer or is it having same issue? If its having the same issue then there is something wrong with your drive. It's failing to install the drivers due to either hardware failure or corrupt firmware. You can learn more about the recovery process for external hard drives here as well as get a free phone consultation on the official SERT Data Recovery website.
Nov 29, 2013 | Toshiba 320gb 7200rpm 2.5 Sata Hd Hdd2f23...
Hallow ma names Isaiah and I would like 2 Install windows XP on my Toshiba Satellite Pro A200-EZ2204X PC Note book because I replaced the harddisk after a recent harddisk crash but everytime I boot my...
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please restart the machine and tap the F12 key on the initial toshiba logo
this would reach the windows one time boot menu. You can select the cd drive as a one time boot option and initiate XP installation.
Nov 21, 2010 | Toshiba Satellite Pro A200-EZ2204X...
I upgrade my toshiba L305-S5911 frm vista to
What I would do first is, try to install and test it with yahoo messenger and try to see if you can connect to any of your friends. Do you have the software install to run the webcam?
May 21, 2010 | Toshiba Satellite L305-S5911 Notebook PC
I have a Toshiba HDD2190 C DC +5V 0.7A 40 GB Laptop harddisk which when I plugged into USB drive (by using a USB cable), WIndows XP Profesional detect it but I can't find it's Partitions in my computer. In...
In general, you need to install the correct drivers for the enclosure, not for the hard disk. Seeing as you have XP Pro, this is probably unnecessary though.
Also, 0.7A is 700 mA, and this exceeds the USB port maximum current which is 500 mA.
Most (not all!) laptop drives will run even if under a slight undercurrent, but this depends on USB port electronics and enclosure electronics.
Chances are that you won't be able to run the disk unless you plug it into an externally powered USB hub supplying at least 750 mA per port. The 100-500 mA supplied by your PC's USB port is enough to power the enclosure electronics and the host controller, but not enough to get the HD to spin properly. As a result, the HD can not be initialised and the enclosure will report an error.
Some hard disk enclosures come with a "USB Y Cable" or "double power cable" which joins two USB ports to get double the current, and can support HD up to 1.0A. If your enclosure comes with one of them, try that first.
Nov 02, 2009 | Toshiba (HDD2190-50PK) 30 GB Hard Drive
Toshiba StorE ALU 3.5" external HDD stops out of the blue.
Toshiba could only replace my HD after destroying the data on it, So I just bought a separate empty HD casing instead and opened the Toshiba casing and took out the Western Digital Harddisk. The harddisk was perfectly working, It seems that the Toshiba controller in their casing got messed up. (Never a Toshiba for me, because by solving the problem myself in the appropriate manner I lost their useless warranty).
Oct 02, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Toshiba latop 0201 #ide problem
IDE #0 is your primary hard drive.
Toshiba's System Errors indicate that the error 0201 Failure IDE #0 may be caused by bad contact points where the drive plugs into the laptop chassis. Toshiba recommends pulling the hard drive in and out several times to clean up the male/female contact points.
Toshiba also said that if this doesn't work to contact one of their service centers for assistance.
The contact points solution rarely works, but is worth a try. Most likely, your hard drive failed and needs to be replaced.
Feb 08, 2009 | Toshiba Satellite M30X Notebook
To insatall xp os in toshiba laptop fresh
make sure you use all the OEM disks with the drivers. if this laptop was not originally XP, use the previous OS that came with the system. and then upgrade to XP
Aug 16, 2008 | Computers & Internet
NEED driver
No driver needed, its a laptop HD right?
Get an Ebay IDEto laptop IDE adapter for under $10.. hook it to your Desktop pc as a second drive, and whack at it with a few disk format utilities you found on google..
It either will work, or its dead.. If it works, put the OS install files on it, put it back in your laptop and install...
Handy things those IDE-laptopide adapters...
Oct 23, 2007 | Computers & Internet
Boot Failure
boot failure could be the harddisk is bad or the os in the harddisk is corrupt, try installing a new os, if failure harddisk is bad.
uzowuanya
uzowuanya@yahoo.ca
Oct 21, 2007 | Toshiba 4030CDT (P000271450) Motherboard
Adaptec (1913500) USB2Connect 3100LP 760884138106 (adap1913500) Logo
Top Adaptec Televison & Video Experts
Are you an Adaptec Televison and Video Expert? Answer questions, earn points and help others
