Question about Car Audio & Video
Goodmans GCE7205USB2 car stereo
I have a Goodmans GCE7205USB2 car stereo and it will only play CD's and MP3 out of the left speaker. When the radio is on it plays out of both.... what is going on and how do I fix it?
otacon
  • 1944 Answers
SOURCE: Act car stereo model no.: hu 3600
Could you please tell me the exact brand and model of your stereo? Thanks.
Posted on Feb 15, 2008
SOURCE: CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
Posted on Apr 05, 2008
Eagleeyes
  • 199 Answers
SOURCE: stuck CD in car stereo
erm Nope. its a strip down
Sorry :(
Mark
Posted on Jul 21, 2008
mumma_1
  • 903 Answers
SOURCE: ''i want to burn mp3 music on cd for my car stereo, but it won't p
if you went to 'audio burning' in nero and chose 'audio cd' then you should really not have any problems because it will play on any cd player. If you still have trouble with this though try burning an audio cd in windows media player instead. Create a playlist, it cannot be longer than 70 mins (i normally max at 68 minutes) then select burn playlist. This should play in your car with no problems.
I hope this helps
Posted on Nov 11, 2008
nuwan chinth
  • 111 Answers
SOURCE: LG car CD, MP3, WMA Receiver wont play or eject CD's??
please observe when you push the eject button display applys the open or eject cd?.if yes something wrong with your mechanisum.it has several microswitches and bad contact of them occur this type problem.sometime loading mechanisum stuck because of loose belts.open the cover of your cd player and check cairfully.
come back with results.
nuwan
Posted on Jan 09, 2009
New Alpine radio, went through setup, plays fine on radio/tuner on all four speakers, but ipod (USB port) or internal CD only plays on front speakers.
Just a thought - the usb provides a digital signal which carries information about how the signal is to be processed; mono, stereo, surround sound stereo, etc.
If the mp3 music file was only recorded in 2 speaker stereo perhaps that is how it plays back.
Admittedly the radio signal is stereo and yet it plays on four speakers but unless it is a DAB radio it is analogue and maybe that makes a difference.
Perhaps there is an internal electronic fault with the digital processing part of the unit. I suggest reading the handbook again and then perhaps contacting the seller.
Mar 28, 2016 | Alpine Car Audio & Video
Radio trouble shooting
It seem like the stereo for the radio is failing, either because of a weak radio signal or defective aerial
Jul 30, 2014 | Mercedes-Benz 1992 Mercedes 500SL Radio /...
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
The speakers in my new 2nd hand car won't play
if one speaker in car is shorted or bad.It will cause the whole system to mute .You may need to have someone to disconnect one speaker at a time or pull out radio.Some systems have a seperate amp in rear of car .Check fuse for that amp//goodluck
Jul 30, 2009 | Car Audio & Video
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
CD player wont play disks, showing error 1 instead
The original user manual will define the headunits error readings. It is most likely an internal mechanical failure and will need to be repaired or replaced
May 20, 2009 | Goodmans CD / MP3 car radio GCE780MPT CD...
Eroor 2 code on my goodmans car stereo
Optic lens error. Replace or repair.
May 10, 2009 | Car Audio & Video
I have bought a kenwood kdc-241 car stereo i have downloaded my mp3 s onto cd-r (about 60 of them)when i put it into car stereo they play but no sound comes from the system (the radio sound is working also...
Hi i have just looked up your stereo and that kenwood doesnt support mp3 playback.
Unlucky mate.
In order to play a cd like that the head unit must support mp3 playback
May 30, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
