Question about Dell Vostro 1500 Notebook
Replaced a broken LCD. New screen is dim. I updated Bios and checked color connections. When I adjust brightness (FN up and down), it gets brighter until 5 and then gets dimmer at 6, 7 and 8...
    Novelist:
  • 225 Answers
Try your laptop connected to an external monitor check if DIM issue can be seen from the external monitor if yes update the video driver.
Posted on Oct 09, 2009
The screen on my Toshiba 1130 has dimmed.Is there any way I can get it brighter, or use an external monitor?
For a quick adjustment of the screen brightness you can also try using the key combinations Fn+F6 (darker) and Fn+F7 (brighter).
Mar 30, 2010 | Toshiba Satellite 1130-S155 Notebook
MY Laptop Screen Is Dim It Will Not Show Bright
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Jan 14, 2010 | HP Pavilion dv1000 Notebook
Cant turn the brightness down on my asus netbook
You should be able to use the "FN" key and "F5" key, press and hold the "Fn" key then while holding that key, press the "F5" key to decrease the brightness. Use the same(Fn) key and "F6" to increase the brightness.
Jan 02, 2010 | ASUS Eee 4G Notebook
How do you make the lighting on the screen brighter without the charger in ?
The screen will automatically dim slightly when it is on battery power, this is to conserve battery power. For maximum brightness connect the power adapter into the laptop.
On the Thinkpad laptops you can adjust the brightness by pressing and holding down the blue Fn key plus the Home key to brighten or the End key to dim the screen.
Nov 26, 2009 | Lenovo ThinkPad T61 Notebook
I need to lighten my screen
this is not a computer problem you have to press the buttons on your monitor that is a menu when the menu comes up change the brightness
Nov 14, 2009 | Averatec 7171000100 Keyboard
How do i make my screen brighter on presario v2000
Decrease Brightness (fn+f7) The fn+f7 hotkey decreases the brightness of the notebook screen. The longer you hold down the fn+f7 hotkey, the more the screen dims. Decreasing screen brightness conserves power. » To increase screen brightness, press the fn+f8 hotkey.
Increase Brightness (fn+f8) The fn+f8 hotkey increases the brightness of the notebook screen. The longer you hold down the fn+f8 hotkey, the more the screen brightens. » To decrease screen brightness, press the fn+f7 hotkey.
Nov 03, 2009 | HP Compaq Presario V2000 Notebook
Dell Vostro 1500 - just replaced a broken LCD screen. New screen is dim. I already checked color connections and screen brightness (FN up and down). How do I brighten my screen?
You are probably not going to like my answer but your new screen may have a bad Backlight or connection, that is what lights up the lcd panel. Check your connection at the inverter just to make sure, sometimes these connection can get reversed or get loose during the reinstall. I would take it back apart and check it from the main cable on the back all the way to the motherboard.
Oct 01, 2009 | Dell Vostro 1500 Notebook
Laptop Screen goes dim when plugged in!!!!
Hold down the Fn key then press arrow key up or down.
Aug 10, 2009 | Gateway 450ROG Notebook
Screen brightness
You have a "FN" key in the lower left section of your keyboard. There should also be other keys with ink the same color as the FN. Look for one that has a sun and upward pointing arrow. Press both and your screen will get brighter.
If that does not work then your video inverter is starting to go bad and will have to be replaced.
Dec 10, 2008 | Acer Aspire 5100 Notebook
Keys dont work.alternative way to change brightness?
Yes you can go into your display properties and look in the settings tab and look for advanced click that and open color tab or the overlay tab, color tab should get your brightness turned up, And if you can't see you can go into your bios and adjust your brightness from there and get it back to where you can see it if you can't write me back here so we can try another method. Ok I hope that helps you out somewhat, Oh yeah you can also hook up an external key board into your usb connections and you should be able to work everything from that too.
Jan 15, 2008 | Dell Inspiron E1505 Notebook
Dell Vostro 1500 Notebook Logo
201 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
