Question about Dishwashers
Whirlpool dishwasher heated dry not working right
We have a new whirlpool dishwasher. The manual says you can use the heated dry option with the glass express, however when we push heated dry the light flashes and goes out. No dry cycle runs.
Customer service read us the instructions out of the manual and said that was all they could do. Any thoughts?
Krazytech
  • 725 Answers
SOURCE: DISHWASHER LOCK
Try push and hold the cancel button for 5 seconds, if that does not work, then unplug the machine for 30 minutes and try holding each button for 5 seconds start with Dry then energy saver button... hope it helps.. let me know Thanks
Posted on Aug 15, 2007
SOURCE: Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
SOURCE: Whirlpool Gold GU15 dishwasher won't start
The appliance repair technician just diagnosed the problem for me. He says it's a bad touchpad, and it would cost $257 for him to replace it. Thought I'd share the diagnosis in case anyone else comes upon this thread.
Posted on Sep 02, 2008
  • 338 Answers
SOURCE: Whirlpool Type 575-0 Dishwasher has a film on the glass ware
try only filling the detergent cup halfway. but before doing that run a cup of vinegar through the dishwasher. that should solve the problem. you are using to much detergent. plus use powder detergent if it is stated in your owners manuel.
Posted on Nov 26, 2008
rylee_smith
  • 8619 Answers
SOURCE: Dishwasher: Green light flashes and will not turn on
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 10, 2009
Dishes are soaking wet at end of cycle. Is this normal?
No, it's not normal for them to be soaking wet at the end of the cycle, but there are things that can affect this. First, make sure you have Heated Dry selected. Next, make sure you are using rinse-aid (Jet Dry), because the new dishwashers don't use as much heat as the older dishwashers, and Jet Dry will greatly aid in the drying. Be aware that plastics won't get dry in any dishwasher. Other things you can do is turn on the extra heat options in the wash cycle, and turn on the Sani-Rinse option (if you DW has such options). Otherwise, you may have a heater or controller problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 24, 2015 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Dishwasher Model #WDF310PLAW5. It's only about a month old but it will no longer allow me to select the heat dry option.
My Whirlpool dishwasher stopped heating the water and air for the hot air dry option. It would not accept the command for these options. My older unit had a burned out heating element in the bottom of the wash cabinet. Yours may be burned out or simply have a loose connection to the heating element. Part is not expensive, but the installation is a bit extensive. It should be covered under manufacturers warranty.
Dec 04, 2014 | Dishwashers
I have just moved into a home with a 1 year old Whirlpool Gold GU2400XTP Quiet Partner III. THE DISHES ARE NOT CLEAN, GLASSES HAVE WHITE SPOTS, SILVERWARE AND PLASTICWARE HAVE WHITE FILM. I am using...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
What is heated dry option
The heated dry option uses forced air from a blower and the dishwasher internal heating element to dry the dishes.
Jun 02, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a Whirlpool Dishwasher Model #GU240CXTPB1. The normal light won't stop blinking. Tried turning the breaker to reset, but still blinks. No other button works.
Whirlpool dishwasher reset sequence is usually to hit the heat dry then normal then heat dry then normal buttons within 5 seconds and it usually resets.
Mar 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher won't start
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Jan 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool DU1145XTPPB7
These dishwashers normally have a "Control Lock" mode.  It's in the manual.  It is provided for child safety.  It's often controlled by holding the "No Heat Dry" button for 4 seconds or more -- same procedure turns it on or off.
Feb 25, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool GU2400XTPT6
Check the Tech Sheet you will find it behind the kickplates On many models, this sequence will work: Heated Dry, Normal, Heated Dry, Normal. Press this key sequence within six seconds to activate service mode.let me know if it helps
May 06, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
316 people viewed this question
Top Dishwashers Experts
