Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Inside wall warm
Side-by-side: Refrigerators inside wall next to freezer is very warm. Why?
    Problem Solver:
  • 7 Answers
Possibly the Mullion heater which keeps the door gasket from freezeing when the door is shut and humidity is high.
Posted on Oct 04, 2009
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
My food in my freezer is getting fuzzy with frost, why??
if thers warm air leaking into the freezer this will happen,but if the rear inside wall of the freezers covered with a icy/frosty covering too,this indicates a defrost problem,remove rear wall inside panel in freezer and defrost with a handheld hair dryer,then test the defrost heater and thermostats both located on the evaporator coil thats frosted over,its most likely one of these or possibly the defrost A.D.C. control
Feb 15, 2012 | Kenmore Side by Side Refrigerator
I have a side by side refrigerator and the freezer is not cooling, what do you think the problem is?
if the refigerator and the freezer are warm,i'd have to say you have a bad computer board,they go on the ge's all the time,let me know if there's ice on the back wall inside the freezer or is it warm in both sides,also send the model number,it should be on the right side wall in the fridge up near the ceiling or if it's older it could be down near the bottom hindge on the fridge door
Sep 01, 2010 | GE Refrigerators
Fridge is look warm but running freezer remains frozen
check your evaparator fan motor if its not working it wont pass the air to the fridge.. its inside the freezer possibly might have to remove back wall inside
Jan 30, 2010 | Maytag MSD2756G Side by Side Refrigerator
The freezer section seems to be leaking some water at the bottom
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)
Dec 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from refrigrator
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Oct 10, 2009 | Kenmore 57029 Side by Side Refrigerator
GE side-by-side fridge is warm at the top of the freezer and fridge but freezing at the bottom of both, any ideas?
Either the fan in the freezer is not working , or you have a defrost problem ( frost on coils & rear inside freezer wall ) .
Sep 07, 2009 | Refrigerators
Warm refrigerator
Check if the freezer coil , in the back wall inside the freezer behind a pannel , is probably block with ice , that means the defrost timer or the heaters don't work.
Mar 13, 2009 | GALAXY Microsystems 25.4 cu. ft....
Side by side frigidaire
check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Jul 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
