Adjusting volume on FM radio on Fuse then screen went blank. Wouldn't shut off. Mac user. Reconnected to mac then rebooted the Fuse did the fireworks thing and then posted a FAT error connect to PC. What about Mac users? I'm frustrated, had a Sansa Clip that was defective and took months to replace it through Sansa. Now this.... AUGH!
Download the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB
mode located on the sansa if asked to change to MSC goto menu press
enter scroll to settings press enter scroll to usb mode press enter
scroll to msc press enter press menu.....Connect should auto start
sansa software..... Sansa software/driver Updates firmware follow
instructions Downloads manual Downloads converter
Set sansa to recovery mode, Start the updater plug the sansa into the computer, unplug when told sansa, should restart (Lock sansa press and hold rec and menu until recovery begins)
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Hold switch up for 15 seconds, this will reset the dam thing
