Question about Palm Pre Cell Phone
My pre says memory critical too many cards. I have 7.1 gigs still available. help
My palm pre says "Sorry, too many Cards" Please toss away any youiare not using to make room for more.
What does that mean???
Posted on Oct 06, 2010
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
Hi i just built a new PC with 2 x 2gig memory now under computer properties it says 4 gig installed but only 2.99 gig useable and the new motherboard will support upto 16 gig. Using Windows 7 Ultimate...
Looks like one of the 2gb mem card you bought and installed is defective.
Check each one and clean the gold terminals using a pencil rubber eraer, clean it an install it again, move it to side to side just to perfectly fit the contacts.
If both mem card is working the problem would be the memory socket terminal, either it is dirty or the pin connector is burned.
If one is not working, return the mem card and have them replace it.
Hope FixYa helps you out!
Sep 13, 2011 | Computers & Internet
Storage memory es critically low.
memory that comes with cell is 64mb (actually 47mb)..if you put a tune or photo or two itake up some space...you have slot for expansion memory cards (microsd) try a 2 gig...cost is no more than $10
Jun 09, 2010 | HTC Touch P3450 Smartphone
Program leaves tracers and the background turns white can't figure out why. and it runs very slow. had no problems before i put windows 7 in.please help!
Are you using a licensed windows 7?? If not you will certainly be having problems. This sounds like a problem with your video card. Also do not try to use windows 7 unless you have a minimum to one gig memory and even that is barely enough. Best to be using two gigs and at least a 512 video card. Also, if you were running xp before,, it is important that the system was formatted before installing windows 7.
Dec 14, 2009 | Computers & Internet
When i insert my 16GB SONY PRO DUO MEMORY CARD. my psp says no card inserted and the orange indicator light keeps flashing!! help!!
what has gotten to ur soul?
tryying to insert an 16 gig memory.
minimum is 1 gig
then normal is 4 gig
next to is is 8 gig but it run slow
chage that to 4 or 8
or u can dl memory backker for psp
google it.
it enables a sony psp to read an 16 gig and faster 8 gig.
gudluk
Dec 09, 2009 | Sony PSP-3000 Black Console
Can't move photos from internal memory to memory card
Yes, it can be done. Here are the steps to copy them over:
1. Turn on your camera
2. Press the button to view the pictures you have taken (the button that has the green sideways triangle with the green square around it).
3.Press the Menu/Ok button
4. Arrow down to "Copy"
5. Press the Menu/Ok button
6. To copy the photos from the internal memory to an SD card simply hit Menu/ok button again.
7. Arrow down to "All Frames" and then press Menu/Ok
8 It now asks you to confirm. To continue copying the pictures over, press Menu/Ok again.
9. It will now begin copying your pictures over.
There you go. Hope this helps!
Jul 16, 2009 | Fuji FinePix S700 Digital Camera
Format and Check SD card
Purchase an inexpensive card reader such as the Ativa, available at Staples and Office Depot for $9.95. Put your memory card with the photos on it into the reader and plug it into a USB port on your computer. Windows will recognize it as another drive and assign it a drive letter. Using any graphics program, or Windows Explorer, navigate to that drive, open the file containing the pics, click select all, and copy the pics to a file on your computer. Make sure that all the pics have transferred or copied to the new file. Replace the card back into your camera and format the card so it is empty and ready to receive new pics. FYI: Less than 1 gig memory cards are available on ebay for dirt prices. Also, go to the camera manufacturers website and see if they have a firmware update for your camera that allows larger than 1 gig cards to be used. I had to do that for my Fuji S700 so I could use 4 gig cards. It used to max out at 2 gigs. If this has solved your problem please rate it accordingly. Good luck.
Jul 05, 2009 | Samsung Digimax S800 Digital Camera
Palm Pre Cell Phone Logo
690 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
