Question about GoVideo Go Video DVD/VCR Combo
No power. I changed the fuse. Still no power. Tape stuck in machine. It is a double recorder
    President:
  • 2,187 Answers
Inspect the power supply circuit. It is the first circuit in series with the power cord. Check if there are burnt parts especially leaking capacitors. If you have tester check if there is power coming from the power chord and then from the power supply circuit. If there is no power from the power supply circuit look for the items mentioned above or the circuit may be bad. While at it look for other burn components or leaking capacitors on the main board. Chances are the issue is with the power supply circuit as this is the first to go during a surge or a wrong voltage was supplied.
Posted on Oct 04, 2009
How do I set up my jvc_td309 double cassette deck for recording on cassette tapes? Also what settings?
Adjust recording bias, if one, for the kind of tape you are using and you are good to go. For best performance use the brand of tape that was used to set up the machine when made.
If you have a fine tuning control for the bias, use it per instructions for best frequency response and s/n ratio.
Nov 16, 2015 | Audio Players & Recorders
Toshiba vcr tape stuck after power outage
Do you have any small children who have access to the machine? Kids are notorious for posting coins, half eaten biscuits and bits of toys into the tape slot. 1st give the machine a light shake and see if it rattles, next remove it from any power source and remove the cover. You may find something obvious, if not, reconnect the power, being careful not to touch anything inside, and try to load a tape. Dirty heads WILL playback, but will NOT record. The standard for these machines is load spool to erase head, to video head, to soundhead, then between drive spindle and pinch roller and on to take up spool. Has the tape you are trying to record had the tab removed, if so (like a pre recorded tape) it will NOT record until you place a piece of tape securely over the tab hole.
Jun 21, 2014 | Toshiba Televison & Video
Reel to reel wont record with microphone
When I put a tape in and press play, the spools will not turn. There is power, but it won't play the tape. It's like the turning spools are stuck .
Feb 28, 2014 | Audio Players & Recorders
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
How do I change the vcr to 'SLP' - it seems to be stuck on 'SP'. (There is no "speed" button on my remote.)
Use the remote to get into the setup menus. There may be an option to change tape speed when recording. Alternatively, when you press record on the remote (or deck), you may have option to change the tape speed there.
The VCR part of your deck may be able to playback, but not record in SLP mode.
Searched around for the manual for your machine, and though there are references to it, it appears that a manual / information page doesn't exist for the model # that you listed.
Jun 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
Incorrect record speed
do you have a reel to reel deck or another machine? You may also need a schematic. Make a copy of about 2 minutes of a tape on a working machine. Keep the original in the working machine. Each cassette deck needs a different size belt. Try putting different size rubber bands on it. Cassettes usually play at 1 7/8 IPS (inches per second) each speed increases or decreases by doubling or dividing by 2.
Aug 30, 2008 | Marantz PMD101 PORTABLE PROFESSIONAL...
My timer recording funtion isn't working
you might have an object stuck inside or the belts need to be changed. also the idler could cause this problem. hope this helps.
good luck.
Feb 08, 2008 | Televison & Video
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
GoVideo Go Video DVD/VCR Combo Logo
70 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
