Question about Intel D845GVSR Motherboard
Hi! I'm need a Pci simple communications controller for fix my PC Dell dimension 8100 window XP Sp2
  • Hans De Becker
    Hans De Becker May 11, 2010
    what kind of simple communications controller? what kind of device do you want to connect?
    Genius:
  • 1,066 Answers
Download it from the dell website
Posted on Oct 09, 2009
Hi go to dell site the pci is a modem pug on to the router the pci will go the other usb will be ok if you go on to the dell site and down load the usb ,regards clive
Jan 27, 2012 | Dell Dimension 3100 PC Desktop
Hi! My dell-dimension 8100 with 40GB was working ok till i up grade with 400GB. After the up grade,my desktop chould'n notice the new hard drive and chould'n instaul window xp. Please what should i do?
When you boot your computer, spam the F2 key to enter the BIOS setup. Select the Drives/Drive Configuration menu, make sure PATA-0 and PATA-1 are enabled. (or whatever is listed for your physical drive ports, the Dimension 8100 doesn't use SATA so those shouldn't be listed). Save settings and restart. XP should now be able to detect the new hard drive.
Sep 29, 2010 | Dell Dimension 8100 PC Desktop
Pci simple communications controller ....no driver.....using xp pro sp3
thats the problem sp3. i suggets you go back to sp2 or you try to use sp2 driver on sp3. extract it to a folder and go to device manager and install from there,
pls rate me thanks
Jan 21, 2010 | Systemax (100621) PC Desktop
Did a clean install of windows xp SP2 and am unable to connect to the LAN connection between the NIC board and the broadband modem. Error message tells me simple communications controller is missing. What...
Hello.
When you performed the Windows XP install, not all the drivers were available and installed.
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Dec 21, 2009 | Office Equipment & Supplies
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
Problem with Dell 4600C
Dimension 4600C driver
Developer: Dell
Version: 1.16.0
System: Windows XP,Windows 98,Windows ME,Windows 98 SE,Windows NT SP4,Windows Vista,Windows 2000 SP4,Windows 3.11,Windows NT SP3,Windows NT SP2,Windows 95,Windows NT,Windows 2000 SP2,Windows 2000
License: freeware
http://support.dell.com/support/downloads/index.aspx? here you will find your solution
Apr 14, 2009 | Dell Dimension 4600C PC Desktop
Multi media audio controller pci simple communications contoller sm bus control video controller vga compatable all with yellow question mark against them
multi media audio controller
sm bus control
I Have A Service Tag No. but when i Write the Number He Is Not Working
i Need Your Help
Nov 03, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dev Man Errors / drivers
Go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag",(serial number) of the 820 laptop. Dell keeps a listing of drivers for every customer's computer they sell.
The PCI device, simple communications controller is your dial-up modem card.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Jul 01, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Intel D845GVSR Motherboard Logo
286 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
