Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I have just unbloked a paper jam on my kodak esp3 priner.. now wen it goes to print the ink thing goes from left to right makes a horible noise and stops... its wont go back to the left :S:S
  • 8 Answers
F you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Posted on Mar 05, 2010
Kodak ESP3 not printing
Don't have a solution but can confirm this printer seems to be full of bugs. I have reinstalled software twice which gets the printer going for a very short time only. It does not recognise the Kodak ink cartridges..! Very frustrating.
Feb 27, 2010 | Kodak ESP 5 Printer
I have a paper jam in my kodak esp3-cannot remove the paper,how do I do it?
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
http://www.4all2sell.com/pdf/Brother-MFC-7340-MFC-7345N-Manual.pdf
Feb 24, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam on my ESP3 printer. How do I get the
Go to www.kodak.com/go/itg and select all in one printers and then paper jam as your problem. they will give you step by step instructions to resolve the issue. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printer for you free of cost as all the esp-3 printers are in warranty as of now.
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 paper jam when theres no paper
Kodak esp3 always showing paper jam .I have disconnected and followed instructions to fix through IT phoneline No joy! How can I fix this problem ? mary
Jul 28, 2009 | Office Equipment & Supplies
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam
Yes, put it in the box and take it back, and don't look back. A paper jam is the least of it's problems. Wait till you keep track of the ink you use: 4 4X6 color pictures, and 85 black printed pages before you have to replace the inks. I know , I have one, 3 printheads replaced, and recently Kodak send a rebuilt printer. Kodak has big problems with this.
Get an HP printer.
May 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Unable to print any thing
Remove and re-insert the cartridges.
while plugged in.
Clean nozzles, printhead, align etc...
print a test page off
Easyshare are known for eating ink up,
the ink could be all gone.
possible bad cartridge, swap out.
Regards
Richard.
Apr 20, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Paper jam in a Kodak ESP- Printer
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Jan 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
444 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
