Question about Sharp AR-BC260 Color Copier
Error code H5 01
Please help. I switched on my Sharp ARC 260M and the above error code appeared. It wont go off.
Kobe
  • 3 more comments
  • KKDK Dec 23, 2007
    greatbigred
    Thanks a lot. You've saved me pounds(£).
    KKDK
  • tahir malik May 27, 2008
    Error massage is cleared as described in this page but still getting jams at fuser,it looks like page is orinted but fuser is not taking the paper in and its getting jam at fuser unit
    Any solutions plz?
  • Anonymous Apr 07, 2009
    WOW!!! This worked! Thanks a lot : )
  • tocsxoawn May 13, 2009
    Sharp AR-M161 error code h5-01
  • y2k2s2000 May 14, 2009
    Can someone tell me where this fuser exit sensor is?
    Sniper:
  • 54 Answers
It means you have had 5 jams in a row in the fusing unit. Open the left side door of the copier (roll the finisher out of the way if you have one). Open the green handle on the top of the fusing unit and carefully remove all of the pages stuck in there. You can use the green wheel at the back to turn the rollers if need be. If you have no jam, then someone already removed it and you just need to reset the code. to reset the code, push P * Clear * on the numeric pad. when it says enter simulation number, enter 14 and push the Start button for black and white copies. The machine will reboot and your code should be gone.
If you keep getting jams, you may have knocked the Fuser exit sensor arm out of place.
Please don't forget to rate your answers.
Posted on Dec 22, 2007
Also works for model AR-620N - thanks greatbigred!
Posted on Jan 09, 2008
How do I fix error code F2-41 on Sharp mx-6201N?
Hi
This appears to be related to the toner sensor or harness connector. The details are given here:
Error Codes Sharp MX6201N Code F2 41
where you can also look at all the error codes for your machine or change the make & model number by using the drop down menus along the top of the page:
You can also obtain a full service manual in pdf format from this site.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Sharp Office Equipment & Supplies
Sharp arc 260m error code H4-01? can I fix
This is a fuser error. You will need to buy a new fuser and fit it.
May 19, 2011 | Office Equipment & Supplies
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
Sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 03, 2009 | Sharp AR-C270 Color Copier
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
Error code L 1
probally little switch on "ceiling of where paper exits has been bumped locking lens, please rate as fixya or reply
Dec 27, 2007 | Sharp AL-1642CS Copier
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Arc 260m network help?
You will need to use the Sharp Network configuration program. This should allow you to setup the printer for network printing. You will want to use 'manual' settings for the IP. Example
IF DHCP is used, you will want to switch to Manual and put in a 'correct' ip.
IP Address: 192.168.1.189
Subnet:      255.255.255.0
Gateway:    192.168.1.1
The Gateway will not be necessary if you do not plan to use the advanced functions to e-mail scans, and prints.
Sharp Network Administration software link
http://sharp-world.com/products/asia-doc/c/download/license_01.html?link=http://www.sharp.co.jp/print/document/download-e/utility/Sadmin.ZIP
Oct 10, 2007 | Sharp AR-C260M All-In-One Printer
Sharp AR-BC260 Color Copier Logo
4,874 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
