Question about JVC LT-26X506 26 in. LCD Television
Television will not turn on. Power source is fine.
  • 31 Answers
Unplug everything (start with power cord, then av/hdmi) and let it sit for 30 seconds. then plug it all back in and give it a shot.
Posted on Oct 04, 2009
Tv just cut out and gave off a red spark
turn the television OFF even unplug it from the power source then blow all dust out from it you could use a a fine air blower from a compressor whatever you use make absolutely sure there is no moisture in the airlines
Feb 11, 2013 | Computers & Internet
I have a 32inch hitachi and was working fine turned it off and when i went to turned it on nothing happened not even the red light came on have tried changing the fuse and still nothing only had it 18...
Check ur house power outlet source?Yes.Than the tv whole power supply board it is dead,modern electronic equipments rarely have dead fuses alone or only.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 30, 2011 | Hitachi 32LD8700 32 in. LCD Television
T.V won't turn on.....worked fine last night then this morning it won't turn on???
A massive failure occurred when you tried to start it and the power source has been fried. time for a repairman, ASAP or the damage will go bigger and more expensive to fix.
Aug 21, 2010 | Digimate DGL32 32 in. LCD Television
What is the factory reset code for the dell w3201c tv? For some reason, my xbox 360 will not work with the HDMI when hooked to this tv. It works fine when hooked to other televisions, so I am trying...
Code is 3355
If that fails, try this
* Press and hold the Input Source button - on the TV (not on the remote); continue to hold it until the last step
* Press and release the Power button
* The TV turns off
* The TV turns on
* Wait 10 seconds
* A message appears saying the TV has been reset
* Release the Input Source button
Jul 27, 2010 | Dell W3201C 32 in. LCD Television
Blue lines in screen
Follow the steps below after verifying that the issue is occuring on other channels and other video sources.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved, service may be required.
Sep 22, 2009 | Sony KP-51HW40 51" Rear Projection...
I get no picture or power to the tv
Unplug the TV for 15 seconds
Plug in and turn on
set source to av1
select menu
select and enter Setup
select and enter All Reset
If you are able to do this your TV should work fine
Dec 02, 2008 | Protron PLTV-32 Television
Television will not trun properly
This sounds like a safety feature built into the television. It may be trying to protect itself from an unsafe electrical source. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly. Good luck.
Jun 19, 2008 | Da-Lite Televison & Video
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
JVC LT-26X506 26 in. LCD Television Logo
226 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
