Question about Car Audio & Video
Benq PE5120 the buttons on the projector are not responding
  • 2 more comments
  • karenm700 Oct 05, 2009
    Thank you for your response. It all started with the timer needing to be reset, our bulb says it has 3000 hours and currently the timer has 3003 hours so after turning the unit on (on the projector) it warms up, the screen starts. According to the manual, you are suppose to press the exit button for 5 seconds then press the auto button. At this point none of the buttons on the projector work. Even to turn the power off, I have to unplug the machine.
    Any ideas???
    Thanks,
    Karen
  • karenm700 Oct 06, 2009
    Benq PE5120 projector, the lamp was changed, the timer was not, the timer says it has a life of 3000 hours but it is currently at 3003 which is why it shuts down. I need to reset the timer, unfortunately I am not able to use the funtion buttons to do this. I can turn the unit on with the power button but after a couple of minutes it shuts down automatically. If I try to press the power button to shut it down -it won't work it is frozen. I have to unplug the projector in order to turn it off. What do I need to reset the machine? the timer?
    Please help,
    Thank you
    Thank you for your thoughts, I have had the lamp warning come up on the screen. I have checked the buttons, they seem to be fine-the button does allow me to power up the machine -just not power off after the i comes up with the lamp warning.
    I tried starting the machine without the data cord, still nothing changed.
    Do you have any other suggestions?
    Thanks,
    Karen
  • karenm700 Oct 08, 2009
    Hi, the power works on everything, it just won't shut off with the power button.
    Any other suggestions on resetting, (getting out of the frozen mode that it is in)???
    Thanks,
    Karen
    President:
  • 1,734 Answers
Possible reasons are:
1) There is no power from the power
cable.
=> Plug the power cord into the AC inlet on
the rear of the projector, and plug the
power cord into the power outlet. If the
power outlet has a switch, make sure that
it is switched on.
2) Attempting to turn the projector on
again during the cooling process.
=> Wait until the cooling down process has
completed.
3) The lamp cover is not securely
attached.
=> Correctly attach cover
Posted on Oct 08, 2009
  • 11,896 Answers
Either the control panel electronical unit is faulty or the ribbon cable that connects it to the main base unit. You can test any capacitors with an ohmmeter.
Posted on Oct 06, 2009
  • 19,396 Answers
You can try disconnecting the power cable for ten minutes. This will reset the projector to factory settings. If that does not work, then the projector is faulty, and it is not just a matter of lamp replacement, or you would get the lamp warning. In that case the projector must be tested by a technician to find and fix the fault.
Also ensure that no button is stuck, and start unit with no data cable attached.
Posted on Oct 05, 2009
  • 284 Answers
Are the lights our completely?
It might be as simple as a fuse. Check all the likely fuses in your fuse box ore OK
Also check if there is an inline fuse anywhere along the power line.
If this is not the case are there any other symptoms you can tell us about?
Hope this helps.
Doug
Posted on Oct 04, 2009
Lamp
Hi
I have a Clearco projector
I just stopped working,not even a sound
Apr 07, 2013 | BenQ PE5120 Multimedia Projector
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
Lamp died and remote does not work
I don't think the problems are related. The bulb shouldn't have failed as it is rated at 2000 hours. As for testing the ballast I don't believe that a conventional meter would do it. You would need a lamp testing device. For more go to http://www.myprojectorlamps.com/testing.html Since projector lamps or ballasts are not cheap you may want to have a a/v repair shop check your projector, because of the early bulb failure.
Feb 02, 2010 | BenQ PE5120 Multimedia Projector
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
Replacing the lamp
We contacted BenQ's technical service people from the toll free number on their website. They had us do the same thing the manual said to do and of course the lamp hours would not reset. We had to send the projector to them and they responded that our mother board went and that it needs to be replaced. They've quoted us around $180. What happened to us was that we didn't change the bulb when the warnings came up on the screen. It isn't explained anywhere that if you wait til you get to 3000 hrs without changing the bulb that you could screw up your machine, but it's kind of looking that way. If I were you guys, I would make that call to their tech support and see what they tell you.
Aug 29, 2008 | BenQ PE5120 Multimedia Projector
Benq PE8700 - Won't Power Up
Hi there
Trust me that the Mainboard needs replacement.
I am very familiar with the PE8700's as I am a ASP Technician for BenQ.
Visit www.BenQ.com and look for the link to your country - you should be able to allocate a Approved Service Provider.
Must warn you that the Mainboards on these models are quite expensive.
Mar 29, 2008 | BenQ PE8700 Multimedia Projector
Resetting the lightbulb in my benq projector
press and hold exit button for 3 seconds or more and OSD will pop up, then follow instructions
Dec 28, 2007 | BenQ PB6110 Multimedia Projector
Problem in logic card of the projector
BenQ has support in India: http://www.benq.co.in/ India India Customer Help Desk 1800-22-0808 (Mon to Fri 0830-1730hrs) Service ID service-In@BenQ.com Sales ID SalesEnquiryIn@BenQ.com (Lunch time : 1:00-2:00hrs PM) But this model is out of production so you may have trouble getting parts.
Sep 28, 2007 | BenQ PB6110 Multimedia Projector
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
