Question about Great States Corp. 16 In. Scotts Elite Push Reel Mower
How to adjust blades to cut evenly? - Great States Corp. 16 In. Scotts Elite Push Reel Mower
    Problem Solver:
  • 15 Answers
Should be a screw iether side above the blade turn clockwize to close the gap between  the blades both sides should touch the cutting blade on the bottom you have to turn the centre blades by hand to make sure both sides are even but be careful not to catch fingers on the blades while turning
Posted on Oct 16, 2009
Brother lb6770 The hook comes out and usually misses thread it is supposed to cut even when does catch blade fails to cut thread.Is this adjustment that's needed or replacing?
If the felt pad is missing from your bobbin case, it won't catch the thread properly and if it's not cutting even when it has caught. The cutter blade needs to be replaced.
Aug 30, 2016 | Brother Sewing Machines
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
How do you adjust the deck to cut evenly on a craftsman riding lawn mower.
make sure tire pressure is even first. one of deck hangers ether has an adjustable bolt and nut or ecentric. point blade tips out measure from tip to ground adjust nut up or down to even out. if ecentric loosen jam bolt in cente then turn bigger nut till tips are even tightn jam bolt
Jul 17, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Toro 1991 42 inch mower doesnt cut even how do i
The blades should be a simple bolt on, how ever there are no adjustments at the blade. Your adjustments are on the swing brackets that raise and lower the deck.
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
How do I adjust the blades or sharpen blades on a Andis T-Outliner trimmer? I have some older blades that work farely better then my newer blades that are dull if you ask me. Is there some way to manuver...
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at clipperparts.com
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Feb 05, 2010 | Andis 04710 Beard Trimmer
Cut is always crooked. From the top to the bottom of the cut is always crooked. Can not get the saw to cut a 90 degree ( or even close to 90) angle. Even of I adjust the table to be out of square to the...
It sounds as though you may be cutting too quickly. Try decreasing the pressure you are applying to the wood.
You could also try tightening the blade more, until it PINGS when you flick it with your finger.(When it's stationary of course)
I'm assuming your guides are adjusted correctly.
JR
Sep 27, 2009 | Ryobi 9 in. Benchtop Band Saw
Serger blades do not cut.
For now, it works only satisfactorily:
I applied alcohol to further clean both blades,
dried and then oiled them. There seemed to be a slight gap between blades;
the fabric was dragged into the gap instead of being cut.
Jan 10, 2009 | Elna 1010
Great States Corp. 16 In. Scotts Elite Push Reel Mower Logo
424 people viewed this question
Top Great States Garden Experts
Dennis Key
Dennis Key
Marco De La Fuente...
Salvagedrover
Are you a Great States Garden Expert? Answer questions, earn points and help others
