Question about Toshiba 32AV500U 32 in. LCD HDTV
Toshiba 32AV500U HDTV keeps losing channel 2.1
I'm trying to help out my elderly neighbors. Channel 2.1 (KCBS OTA - Los Angeles) keeps disappearing from the above TV. All other local channels have no problem. The only way to get it back again is to do a complete rescan, which then adds back in the multitude of Spanish and Asian channels which then need to be manually disabled. After the re-scan channel 2.1 has a strength of 97% and the picture looks great, but after a couple of hours the channel disappears again. It doesn't just get poor signal quality - it completely goes away, can't be manually tuned and once again it has to be completely rescanned. Rescanning and manually tuning out the unwanted channels is no easy task for an elderly couple and they usually end up calling me over to help. Their other two TV's have absolutely no problem with channel 2. They have a great antenna with pre-amp and proper cabling to all three TVs. I suspect a firmware issue because no other channels are having a problem and it is suspicious that only the first channel in the list is affected. Toshiba says there isn't a firmware update, however.
Has anybody else seen this issue or have a recommendation?
Elderly couples have had enough trouble with the HDTV transition, they usually can't (or don't want to) afford satellite or cable, and it's pretty aggravating they have to put up with issues like this!
    Top Expert:
  • Toshiba Master
  • 50,270 Answers
Check the location of their antenna and direction it is pointing . it possibly needs tweeked just a little toward the station transmitter
Posted on Mar 02, 2017
3 Suggested Answers
dave1645
  • 834 Answers
SOURCE: We just need to know what to push on the remote to
go in to auto set up or channels and set to air and rescan
Posted on Dec 27, 2009
  • 5341 Answers
SOURCE: some of my channels were lost after I TRIED RESCANNING I I LOST
Check your antenna direction (antennaweb.org or tvfool.com are good sources for signal direction). When I lose channels, it's a digital signal that came in with "bad signal" strength and my external antenna has rotated in the wind. (Oddly another TV in the house doesn't seem to lose the signal as easily even though they share an antenna.)
Also check the weather conditions and time of day. I've gained distant channels when scanning near sunrise or sunset and lost others during thunderstorms.
I hope this helps.
Posted on Jun 07, 2010
Cant get my digital antenna to pick up any channels
In your area, it may be necessary to use an antenna with an amplifier.
Jun 29, 2017 | Televison & Video
Sony bravia is stuck on one channel and won't change to any other station
Same thing happened to me when I was channel surfing and landed on channel 18.7 in los angeles.
What worked for me was turn the power off and then back on. While it is powering on press the channel button either up or down quickly. It should jump channels. It only jumped one channel for me and was still frozen. Repeat the process and I was able to jump more channels out of the trouble zone and back to normal.
Once my tv was working again. I tried to autoprogram my channels again but it still picked up 18.7.
Also tried to "hide" the channel in channel management but it would go to 18.7 and froze up my tv again :(
Hope this helps anyone that has the same problem.
Jan 23, 2011 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
32av500u toshiba remote is having problems. Some buttons, such as volume, work others, power and channel, dont.
The tv remote CPU is shorted and dead.Try website like Remotes.com to buy an exact remote to the original remote.
Oct 24, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Our Sony Bravia TV is stuck on one channel and will not advance to any other station. It will not change to any other component aduch as video 1 or 2. an you help?
Aug 31, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My Vizio turns itself off on a certain channel (ch 17-1 Phila)
I have this same problem with channel 5-1 Los Angeles anyone have any advice?
Aug 29, 2009 | Vizio VW32L 32 in. LCD HDTV
Recent digital conversion - cannot pick up all local channels
Have you gone into your tv's setup and reprogrammed or scanned the new channel assignments?
BTW, what is your tv model?
Jul 07, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
I have a 32" Toshiba 32AV500U 32-Inch 720p LCD HDTV along with a HDTVi VHF/UHF HDTV Indoor Antenna. I purchased the TV and antenna about a year ago. I am unable to get any digital TV, only analog. I was...
Look in your manual for a channel scan entry. It should be an item in your setup menu. What this does is re-scan for all the signals it can receive.
Once the scan is done, it should display all the channels that are viewable in your area
Jun 20, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Tv guide/tuner problems
Most likely the TV Guide is broadcast from the OTA PBS channel. I don't know why its being lost. I'm thinking its probably a firmware problem of some sort. Adding the PBS channel back in, making sure the signal comes in ok and leaving the TV off for a while might help.
Dec 25, 2007 | LG 26LX1D 26 in. LCD HDTV
Toshiba 32AV500U 32 in. LCD HDTV Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
