Question about U-Line 75R Refrigerator
U-line 29RBK Repair
My undercounter refrig quit working - is there anything I can check - I believe it tripped the breaker.
  • 286 Answers
This is not the breaker, This is usually the thermostat that doesnt turn the compressor and fan on
Posted on Jun 20, 2009
  • 833 Answers
First, reset the breaker. If the unit restarts, you're okay. If possible, change to another good circuit of comparable rating...generally at least 15-20 amperes...sometimes the breakers go bad. You may have a bad compressor or compressor start relay. We can only know about that after the breaker is ruled out as a cause. Oh, and be sure the plug contacts are not corroded. If they are: use a little steel wool to clean them and remove all strands when you're done.
Posted on Dec 22, 2007
Hi there, I have a Whirlpool quiet miser heat and air unit (220) just quit working
Check the drain line and look for a safety switch. Need to shop vac the drain line and possibly the float switch cup. Hope this helps!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 17, 2017 | Whirlpool Heating & Cooling
Whirlpool undercounter ice maker trips breaker
If it trips the breaker either the wiring to the ice maker is shorted or the ice maker itself is shorted, do not continue to use it, there is afire hazard if you keep resetting the breaker.
Jan 16, 2017 | Whirlpool Kitchen Appliances - Others
Where is the fuse for a 9 year old Kelvinator undercounter oven situated?
There is none. Look in the circuit breaker box on the outside of the house for the one marked oven. It will be 2 breakers side by side with a metal part connecting both levers together. Move both handles back and forth a couple of times. That may restore power to the heating element. If one breaker trips it leaves 120 volts to work the light and the clock, but the element is 240 volts. It may have shorted with age. You may need to replace the elements if the breakers keep tripping after you reset it at the panel.
Jul 28, 2016 | Ovens
15 amp cutler hammer branch feeder type AFCI triped off and will not turn back on. I have tried switching off for 10sec and then back on and still nothing. Also, the test button will not do anything. The...
if the breaker has tripped the test button won't do anything ,, for the breaker to trip something down stream of it is causing this to happen,, check all the switches and or receptacles in the circuit that are controlled by this breaker, 3 types of line problems cause tripping,, ground to line, Line to line, and line to neutral. in this ,, also consider that extension cords, faulty appliances , ( lamps, radios, anything plugged in with a feedback short ) will cause the breaker to trip. even a nail to hang a picture that pierced the wire can cause this, add to that , a AFCI breaker will trip much more easily than one thats not, or even a GFI breaker, , try this, if you have the knowledge to do electrical work in a panel, if not get someone who is, switch the tripping breaker with another one of the same value, ( in this case 15 amp) see if the one you put in place of the one thats giving you problems trips. If it doesn't, you have a weak or bad breaker, so just replace that one, if it does, your going to have to trace out that entire circuit to find the reason for the feed back into the panel
Oct 07, 2011 | Electrical Supplies
Freezer keeps tripping breaker
Possible that it is draining a larger current and so it trips the breaker. Check if the capacitor to the motor is faulty, replace if you find it on test to consume more current and low charge.
Also the motor can be checked , the wiring to the freezer specially the GROUND connection as any leak can also trip the circuit.
Jul 18, 2011 | Silver King 1242.90 Front Breathing...
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
Where is the 15 amp fuse and breaker on frigidaire FRT17B3A and thermostat my refrig is not getting cold
the breaker [fuse] is not on fridge its in ur breaker [fuse] panel if it not getting power check to see if breaker tripped if power to fridge in freezer section check the fan thats its working and not frozen,blocked,or burnt out if not moving repair or replace and clear any ice or debris in fan chamber[duct]
Jan 19, 2010 | Frigidaire FRT17B3A Top Freezer...
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
I have a undercounter front opening doorDelfield freeze
Hi debbie. Before you hire any repair man please price a new one. The new ones run on 1/6th the electric as the old and they are often under $200. Check them at Home Depot or lowes, even KMart which now handles the Kenmore/searss line. I believe you will end up replacing as opposed to repairing.
Aug 04, 2009 | Freezers
U-Line 75R Refrigerator Logo
189 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Marvin
Marvin
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
