Question about JVC AV-48WP30 48" Rear Projection Television
Screen turning green - JVC AV-48WP30 48" Rear Projection Television
I gotta a green screen
It is possible that you have a shorted green CRT, you can remove the front speaker cover, and you will fine a focus block, and if you turn down the green screen voltage, very slowly, the green should turn down. if not then the gun (CRT) will have to be replace, If it does turn down, then go into the menu and turn the color are the way down and that should give you a black and white picture. If it is not black and white. adjust the red, blue, and green screen voltages until you receive a good black and white picture. Turn slowly they are touchy, and if turn to high, you will get retrace lines and the TV will shut down.
Nov 14, 2010 | Toshiba 61A60 TV
After turning on the screen it soon turns a green tint. I just transported the tv could I have knocked something out of alignment?
yes or the green tube is going bad. if it holds solid just a little green, you just need to turn down the screen control for the green drive. if it gets brighter and brighter green until its really intense, suspect bad tube or board.
the green drive knob is hidden in the front, behind the front access panel. its labeled but hard to see, only turn the one know counter clockwise, it will be labeled G and SCREEN, there are 6 knobs
Sep 09, 2010 | Samsung HCL473W 47" Rear Projection...
When I move the The laptop screen turns green and fuzzy
Restart the notebook and press F10 to enter into BIOS which should be blue in colour. The move the laptop and check if the screen turns green and fuzzy.
If the screen turns green and fuzzy in the BIOS, then the isuse might be hardware malfunctioning of the screen and your notebook needs to be repaired.
Jun 08, 2010 | HP Compaq Presario CQ50-110US Laptop
Screen turns green and red lines appear across
my HD LCD used to turn grey on my 360 so i just turned it off then back on for the results but of coures it could be the LCD is dying
Dec 28, 2009 | Microsoft Xbox 360 Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Screen turns green and tv powers off.
visit your local service center. you cant do anything more up to this point
Jul 08, 2009 | Sony KP-46WT500 46" Rear Projection...
I have no picture, only green screen and audio when I turn on
i have no picture the sceen is green but i have sound can u help thanks.
Jun 06, 2009 | Polaroid FLM-2011 Television
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Hitachi rear projection tv. screen looks green
Green CRT bad = take off lower front cover, remove access panel
locate screen / focus block.....turn green screen control slightly
CCW............................re-assemble...........T.
Dec 21, 2007 | Televison & Video
JVC AV-48WP30 48" Rear Projection Television Logo
15 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
