Question about M-Audio Fast Track Pro Mobile USB Audio/MIDI Interface with Preamps
Why do my mic sound muffled when i record - M-Audio Fast Track Pro Mobile USB Audio/MIDI Interface with Preamps
Mic sound muffled static
Buy a better mic! This question reminds me of the musicians who invest in a nice JBL public address system but then use Radio Shack microphones. A good quality mic, not GREAT but just good will cost you a minimum of $100. Quit playing with toys and invest in real recording gear. Computers and hard drive recorders can easily record CD quality audio, and-so why would you use a $70 mic?
Sep 10, 2013 | Samson Samtr Meteor Mic Usb Studio...
Why mic sound muffled
Depends on what you mean by "muffled". Internal microphones and standard external ones are not high quality mics, but that sound I would describe more as fuzzy. So if you could be a little more descriptive I could help further.
Sep 03, 2013 | Samsung Computers & Internet
Why does it sound so bad?
It's probably the mic, or you have some mental condition. I'm going with the mic, try returning it and getting a new one and if there's no difference, then try the software you use on whatever it is you're recording it with.
May 27, 2013 | CAD Microphones GXL2200 Professional...
My MD 421 suddenly has no high end. Sounds muffled and distorts when I yell into it.
Check the cable. It maybe damaged. Check your phantom power. If your going to yell into the mic...Turn the input gain down to avoid initial distortion. Not sure of your recording setup, but everything in the chain input to output is key.
You can probably assume the mic to be damaged if these things dont check out.
I have a MD 421.
Mar 31, 2011 | Sennheiser MD421-II Professional...
When recording live music the tone quality fades in and out when the music gets loud/soft- How can I record a constant sound level without this fade/compresion. Thanks
Option 1:
Check your audio settings on your camcorder. You may have an option to zoom in on the sound or record sound all around you. Try switching between either of those and see if that helps.
Option 2:
Add an external microphone
Option 3:
Try to muffle (lightly cover up) your onboard mic to keep the loud sounds from auto adjusting the volume.
Jan 11, 2011 | Panasonic NV-GS35 Mini DV Digital...
The mic play back sounds deep and muffled , i was online chat and when i set up the mic volume, it played back deep and muffled like on the movie silence of the lamb.
Its set too loud and the mic is way to close to your mouth. try seeting the boom mic about 2inches from your mouth!
It's a matter of experimenting with mic placement to get the best results. (If it'sd not a new unit, make sure that the microphone holes underneath the windsock aren't blocked up with debris!)
Good Luck
Jan 17, 2010 | HP RF823AA#ABA Headset
Logitech 9000 recording problem
My suggestion for recording music of any sort is to disable the cam mic and use a good quality mic plugged into the sound card as the mic in a cam is more suited to voice.
Aug 24, 2009 | Logitech QuickCam® Pro 9000 Personal Web...
Hp Dv6000, problems recording with built in microphones
go into your device manager and disable the onboard microphone
Feb 13, 2009 | HP Pavilion dv6000z Notebook
How do i disable my built in microphone?
double click on the sound icon in sys tray to access properties and disable from there or just turn the slider all the way down
Jan 30, 2009 | HP Pavilion dv6000z Notebook
My microphone sounds muffled
Check wind screen. Make sure output level is not higher than volume level.
Dec 09, 2008 | Samson C03U Professional Microphone
M-Audio Fast Track Pro Mobile USB Audio/MIDI Interface with Preamps Logo
199 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
