Question about Hitachi Televison & Video
Hitachi projection TV 60SX123Power to TV but I get nothing. Ready to open it up.
  • danstdz Oct 04, 2009
    Sirs,
    I plugged in my TV this morning after watching it last night and there is nothing. Tried resetting and pulling the plug and putting it back in. I hear a click (like you get when you get when you turn it on but nothing) Tried resetting it with the service reset but no good. Nothing on the screen. Changed inputs still no good. I have it hooked in to direct TV and Cable. Before I open up the back I wanted to know what I should look for. Probably bad news. But I want to try everything before I junk it. (13 years old) Is there any hope?
    Dan Studzinski
  • Hitachi Master
  • 5,138 Answers
Remove Back Look for 2 STK ICs they are big Black ICs replace Both of them Also you will need to replace these resistor as well RK42,RK46,RK50 RK54 RK58 RK62 Have to CK for correct value for your TV .Call Mats Electronics for parts you will also need heat sink silicon to put on back of ICs.1-800-628-1118. Will Post to you Resistors Next.
Posted on Oct 04, 2009
  • ladywinn
    ladywinn Oct 04, 2009
    STK392-110s use 120s or 150s) RK42-3.3ohms RK46-1.8ohms RK50 2.7ohms RK54-1.5ohm RK58 3.9ohms RK62-2.2 Your ICs will have number on them.This the most common repair to these sets.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This problem may be temporary and might have occurred due to overheating on the power board. Try and reset your TV by turning it OFF for 8-10 hours/overnight and check if this resets the TV. if the TV isn't reseted then you'll need to look fir swollen /bulged capacitors on the power supply board.
You'll also need to check for cold solder joints on the power supply board as the components on these TV's are soldered using Wave Soldering Technique, due to which many cold solder joints can occur.
Also check the connector wires coming and leaving the power supply board.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
My TV won't turn on. It was fine this afternoon and when I tried to put in on tonight, nothing.
The key here is does the red power light come on? If not follow power cord inside to the fuse that is directly in line with the cord.
If other let me know.
Apr 23, 2012 | Hitachi 51F510 51" Rear Projection...
Problems with Hitachi 57F500 57 in. Rear Projection HDTV-Ready I went away for 8 days and had unplugged the power surge from the wall. When I got home I plugged it back in and everything connected to the...
one of the fans is not starting up causing the error check youself or have a tech check it out for you common thing when the set has been unpluged and really cools down
Dec 03, 2009 | Hitachi 57F500 57" Rear Projection...
Nothing happens only power button lights or turns off
Count the number of flashes for the red power button. I'm not a Hitachi owner, but you can track one down here on fixya and they''ll give you more info. One of the internal components have failed and is keeping the power supply unit from firing up. Do you hear a relay click when you try to turn it on? If so, how many times does it try to fire up?
May 23, 2009 | Hitachi 57F500 57" Rear Projection...
Tv wont power on
I had the same problem Replace the IC's and it should fix this
Dec 31, 2008 | Hitachi 51F500 51" Rear Projection...
HITACHI MODEL 57F510 PROJECTION TV
had 57f510, not working. i need your help. I turn it on and led light come on and disappear and nothing shown. what should i do?
Nov 19, 2008 | Hitachi 57F510 57" Rear Projection...
HITACHI NO POWER
It sounds like you've lost the primary winding of your High-voltage transformer or the regulator....accordianman
Feb 15, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F510 with NO POWER
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Feb 15, 2008 | Hitachi 51F510 51" Rear Projection...
Tvrepair
Hello my projection screen is cracked and in need to know where i can get it fixed and how much will it cost.
Dec 25, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
