Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error code P 0 3
New install on Mac OSX consistent Error code P 0 3
Mac air white screen on start up no boot
it is most likely that your hard disk has a damaged OSX installed, if you get no error codes then it is likely that the video chip has melted the solder due to over heating, try forcing a shut down by holding the power button down for 8 seconds, then holding the option button turn it on again, if you see other options then its a damaged OSX and will need repair, no screen and its main logic board replacement, go to http://www.thebookyard.com/ they are very good at fixing problems mac related and will offer refurbished machines cheep too.
Mar 13, 2013 | Computers & Internet
Error code 51330
Hello murz42
This error code is generated when the Wii console is unable to connect to the access point.
First of all, check that your router is compatible with the Wii www.nintendo.co.uk/NOE/en_GB/support/wii_support_5251_8071.html?id=8072
Are you using WEP or WPA security on your router? Log into your router using the default IP (if you don´t know this, or how to obtain it, consult your routers manual).
If you are using 64-bit encryption, the WEP key is a 10-character key consisting of numbers or the letters A - F. If you are using 128-bit encryption, it will consist of 26 characters. The WEP key must be hexadecimal. This means that it consists of the numbers 0-9, the letters A - F. It cannot consist of any special signs or letters. If you are using WPA, the Wii is compatible with the following types: - WPA - PSK (TKIP) - WPA - PSK (AES) - WPA2 - PSK (AES)
Next, check if your router is using MAC filtering. You still need to still be logged into your router. Find the section for MAC filtering, which is usually located under a "security" tab or something similar. If the MAC filtering is "on" or "enabled", enter the Wii´s MAC address to the list of approved MAC addresses. To find this, go to the Wii Channel menu, select "Wii settings" - "Internet" - "Console Settings". The MAC address is displayed on the first line.
Hope this helps. If you require any further help, please don´t hesitate to ask.
Good luck
ajblaj
Sep 06, 2010 | Nintendo Wii Console
Connection error code 51301
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);This error is caused by issues with the WEP Key of your wirless network.
To solve this error :
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
If your router is using WEP encryption
  • * Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • * 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • * 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
If your router is using MAC filtering, ensure the DS MAC address has been added to the list of approved MAC address on your wireless router settings
Set your router settings to "mixed" or "b and g" mode when using connection files 1,2, or 3 .
May 01, 2010 | Nintendo DS Lite
I am trying to install software onto my MAC OSX and it will not work. Says cannot operate in DOS mode. I do not know what to do. The UM175 says Mac OSX compatible. Help!
I know sounds dumb but it appears your putting the wrong disc in the drive. Kind of the same error if you try to install a windows file.
Plug and play and update.
Mar 22, 2009 | Computers & Internet
Cant conect to internet
  • Wii Error Code 51300 - 51399
  • This error is caused by the Wii being unable to connect to the access point.
  • Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
    If your router is using WPA encryption, the Wii is compatible with :
    WPA - PSK(TKIP)
    WPA - PSK(AES)
    WPA2 - PSK(AES)
    If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings
Dec 27, 2008 | Computers & Internet
Need to find an upgrade for JamStudio to MAC OSX
if you have a power pc you could get an os9 version and run through classic
Jun 28, 2008 | KB Gear Jam Studio Graphic Tablet
Installing adobe software..got error code 1012 on mac 0sx 10.1
what type of computer are you using. a new one? if a new one you can't work it out due to some software instruction of the old version are being deleted or refined to increase the working capability.some of the code have been change.
Dec 27, 2007 | Computers & Internet
Printer driver for Mac OSX isn't working
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:284:0:0&framed=&docid=ENUS24591&relevance=1 This may just be the root of your problem. How to Install an Older (Legacy) Printer (such as the Lexmark Zx2) in Mac OS 10.4.7 (Tiger) ID:ENUS24591 Overview When an older (legacy) printer model is installed on Mac OS 10.4.7 (Tiger), some extra steps need to be taken because the Print Center cannot be directly launched. Thats the jist of the technical paper. Should help. Good Luck, Tim
Mar 08, 2007 | Lexmark JetPrinter Z22 Color InkJet
Canon PIXMA MP150 All-In-One InkJet Printer Logo
41 people viewed this question
old marine
old marine
