Question about Whirlpool Dryers
Dryer is not heatring up
Electric dryer is not heatring up
    Problem Solver:
  • 18 Answers
Sounds like your heating element may be burned out. On initial start, if the drum rotates, and you have blower air flow but no heat, I would suspect that the heating coil (element) has an "open" in it, i.e., it has literally burned through at one location in the coil, usually at or near one of the support insulators mounted on in the interior rear of the dryer. To replace, access to the interior of the dryer from the front is necessary. Take care installing the replacement coil in that any residual tension on the coiled element at any location along its length will, over time, result in premature, stressed-induced, thermal fatique of the coil. To avoid premature failure, all sections of coil between support insulators should be completely relaxed after installation and prior to initial heating.
Posted on Oct 04, 2009
05 Dakota,4.7L.When I turn off the heater fan/AC,clicking sound under dash.Also happens when control knob from defrost to floor/windshield.Blend door? Vacuum or electric operated And how to fix ?
U need to hav specialist not a dealr fixit. Too hard of a job for layman. Wen in there inspect motor..ac evap n heatr core...ovr tenyrs
Dec 20, 2015 | Cars & Trucks
How to work heatr with electric only
without knowing the model it imposible to help
Oct 24, 2015 | Cars & Trucks
Dryer cannot tumble but heatr is working?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 05, 2011 | GE Dryers
My maytag electric clothes dryer does not turn on. I have checked the electric.
the la1053 thermal has gone bad. Located under the top on the left side back wall. Using a putty knife or flat blade there are 2 spring clips, 1 on each side across the front holding the top down. Depress these and you will be able to lift the top back and get to the thermal locted below the heatre. You'll see 2 white wires going down by the heater these go to the thermal. Hope this helps.
Feb 13, 2010 | Maytag PYE2300AY Electric Dryer
Start button trips the electricity
First thing to do is to remove the rear cover, and see if the inside of the cover is damp , and has a build up of fluff. if it has then get a hair dryer and thoroughly dry the element and stats, and remove any fluff that has accumulated in this area.
Try it before you fasten cover back on, if it still will not start, then disconnect the heatr element and stats, to do this, remove top cover and right hand side panel looking at it from the front.
At the left rear corner you will see the wiring going to the heater, unplug the connector and try again ,if it still trips then it could be a motor or control board and or timer prob.
Make sure all filters and vents are clean.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Maytag gas dryer not heating up.
check the gas or have the gas company check it ... also check the igniter. if it does not glow bright it will not open the valve...
Oct 04, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
