Question about Hotpoint Ovens
Need to set clock on Hotpoint BS21 fan oven
Need to set the clock on a Hotpoint BS21 fan oven. The Hotpoint BS21 I am talking about has 3 buttons about the size of a penny underneath the digital display. One marked +, One marked - and the other with an arrow on it. I have lost the manual but remember that it was a combination of presses to these buttons to do it.
I have seen another post on this site stating that the following link is the manual I require
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85135.PDF
but this is not the one
SOURCE: Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Posted on Jan 17, 2010
JMuskovitz
  • 135 Answers
SOURCE: Clock
Here is a link to the owner's manual: http://www.serviceforce.co.uk/pdfs/U22392.pdf
Posted on Feb 21, 2007
BADBOYJAY
  • 264 Answers
SOURCE: function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Posted on Jan 05, 2008
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Posted on Dec 03, 2008
blackmar
  • 235 Answers
SOURCE: Recently bought this oven (without
I come across this problem often, particularly with no manual. I turn the oven to ON. I then just muck around with the buttons until I find the manual setting. As soon as you find the manual setting the oven indicator will light. You can normally work it out quickly. But make sure the oven is turned to on whilst you are doing this.
Posted on Feb 05, 2011
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Can you tell me how to turn on a tecno fan forced oven? It has been turned off by power interuption and now the clock is flashing with 0.00 and 1 and Auto? Please help.... thanks
most digital clocks have several buttons underneath them they are usually set by pressing 2 of the buttons at the same time and then the up down button for the time sometimes the up down setting is done by rotating a knob you will know when you have chosen the correct buttons the numbers will stop flashing failing that relist your problem with a model name and number if you can find one
May 29, 2011 | Ovens
Need to set clock on oven
Instructions
    • 1
      Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
    • 2
      Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
    • 3
      Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
    • 4
      Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
Mar 19, 2011 | Ovens
How do l use the oven l now how to use the rings but not the oven or the clock
It depends on the make and model but generally there is a dial for the oven and you turn the dial to the required temperature and this normally brings the fan/heater/light on.
Setting the clock depends on wether it is digital or no.
Analogue clocks usually have a large button in the middle of the dial which you turn to set the time.
Digital clocks normally have buttons marked + or - which you depress to set the time.
Jan 01, 2010 | Ovens
How do you set clock on hotpoint bu62 double oven
electronic clock I presume. first of all turn power off then back on. Clock display will now be flashing.
press and hold the two buttons far left and hold in. at the same time press the + or - button to set clock. You should also have a pan icon between the hours and minutes iluminated which means you are in manual mode
Oct 21, 2009 | Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
FAN OVEN NOT WORKING
power went off to the house now cant reset fan oven on hotpoint bs21
May 23, 2008 | Ovens
Function button keeps failing
Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint oven clock
1 make sure all oven controls are turned off 2 press & Hold in both the cook period & end time buttons together 3 with both buttons still held in press either the + or - buttons to set the correct time of day 4 Release all buttons simultaneously the time of day is now set.
Sep 18, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
122 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
