Question about Dishwashers
Machine has power to it but wont start washing cycle
  • Tim Harrigan Oct 09, 2009
    How to I get it open
  • 10,515 Answers
Do not forget to accept the solution, if 100% satisfied from my solution!!
As you are getting the power to the machine, that excludes all issue's that is related with Power from Home.
Now, the procedure for the rest of the troubleshooting :-
1. Door Switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
2. Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
3. Timer or Selector Switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
If the problem still persists, then it would be Control Board. ( Usually the main reason 0.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 09, 2009
    President:
  • 2,187 Answers
Check the switch of the door. Most machines will not start the cycle if it does not detect that the door has been closed. Common problem is that the latch switch is sometimes bent or needs to be just reinstalled. Check as well for loose wires. Other problem is the water. Ensure that water is coming out from the source. THe fill valve may not be opening correctly or not opening at all. You will have to check the electrical motor that opens this one called the solenoid.
Posted on Oct 04, 2009
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hey there.. our power went out on the circuit holding the washing machine and now it wont start a cycle. the lights are on and the start button is flashing but it wont start when pressed.. simpson ezi...
unplug the machine for about 15 minutes to reset it. after that plug it back in that should have reset it and allow it to function properly
Feb 28, 2010 | Washing Machines
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Wont start any cycle
Go to your door latch, there is your first stop.Your power supply waits here at the latch to give the computer a correct start.If its not the latch....I need to know. Post a update on this one. Thanx!
Jun 18, 2008 | Frigidaire ATF6000ES Front Load Washer
My washing machine, after washing, changed to the spin cycle then started beeping so I turned it off, re-started it & when it got to the last spin cycle it just beeped then stopped. Now it wont start. It's...
No power? Let's see if we can solve this problem.
  1. Unplug then plug back again.
  2. Start the program.
  • If beeping send for repair/replacement.
  • If not beeping be happy to continue using your washing machine.
Jan 21, 2008 | Washing Machines
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Fisher & Paykel GW703 wont stop!
It sounds like your machine has been programmed to automatically run through the various cycles continuously. Most likely in error.
Oct 07, 2007 | Washing Machines
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
