Question about Mitsubishi HC3000U Multimedia Projector
How do I find the lamp hours on this fine projector?
  • 74 Answers
Press up, down and enter at the same time.
Posted on Oct 05, 2009
Projector clocked 1000 hours roughly and working fine. However 1 day I tried to turn it own and seems completely dead. no blue light. fuse r al good
Does this projector have an automatic timer that doesn't allow it to turn on after a set number of hours (@ 1000)? If so, you may need to re-set the lamp-hour clock (as if you changed the lamp even though you didn't). Some machines require you to at least slide open the lamp cover to make it think that you changed it.
Feb 13, 2016 | ViewSonic PJD6251 3D DLP Projector
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
Will not coming on ,standby light is orange temp and lamp light not on
hi,
Just try to reset the lamp hour of your projector. For resetting the projector do the following.
While simultaneously holding down MENU/HELP, ENTER and Down arrow button on the projector, Press STANDBY/ON on the projector.
Remember one thing lamp hour reset is recommended only after the lamp replaced. Before going to buy a new lamp just reset the lamp hour and confirm that the projector doesn't have any other problem.
If these doesn't help then check the lamp of you projector chances for lamp became faulty.
ok
Mar 19, 2011 | Sharp XR-10SL DLP Projector
Hello, I am having a problem with my hd72/hd6800. My projector is on its original bulb and has about 500 hours over 5 years. Today i was able to turn it on, but the lamp wont light up. I hear the fan start...
Despite the relatively few hours on the lamp, the fact is it's over 5 years old. It is not uncommon for a lamp to age and be too weak to fire. Replace the lamp, you should be fine.
Jan 25, 2011 | Optoma HD72 Multimedia Projector
Where can i buy lamp for sanyo lp-z5 projector
You can purchase at www.Nextag.com (just verify the part number first) Sanyo Genuine Original 610-323-5998 Projector Lamp Video Accessories: Projector Lamps, Projector Stands - General Audio & Video Accessories: Carts / Stands Part #: POA-LMP94 more ..., POALMP94 Sellers Found: 6 Available Since: May 26, 2008
Lowest Price: $185.00
Average Rating: star-gray-1.pngstar-gray-1.pngstar-gray-1.pngstar-gray-1.pngstar-gray-1.png Your Rating: ', Cancel:'cancel',AR:'Average Rating:'}); //--> (0 user ratings) No Reviews ' Write a Review Description 145W UHP - 2000 Hour Standard, 3000 Hour ECO Specifications Video Accessories Projector Lamps, Projector Stands General Audio & Video Accessories Carts / Stands Lamp Life 3000 Hour ECO, 2000 Hour Standard, 3000 Hour, 2000 Hour Manufacturer Part Number POA-LMP94 Brand Name SANYO Lamp Power 145 W Compatible Devices LCD Product Type 145 W UHP Projector Lamp, Projector Lamp UPC : 610074006343
Oct 08, 2010 | Eiki Sanyo Projector Lamp
I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
Oct 22, 2009 | Optoma EP716 Multimedia Projector
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Can I reset my lamp timer without replacing the lamp?
That should be fine to do. Even if the projector did alter the current based on lamp life, the worst that could happen in the lamp would burn out completely. A good projector should have a safety circuit with a fuse to prevent damage to any internal components. You should be fine.
Mar 25, 2009 | InFocus IN72 Multimedia Projector
Lamp failure
Lamp duty cycle is approx 2300 hours and you know how since long this projector is working with you.
Aug 22, 2008 | Dell 3300MP Multimedia Projector
Mitsubishi HC3000U Multimedia Projector Logo
112 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
