Question about InFocus LP70+ Multimedia Projector
My infocus lp360 turns off after few seconds.
I replaces the lamp in my old infocus lp360 but forgot to reset the new lamp timer or I did not know to do that. Now it turns itselk off after 5 seconds. Can you help?
  • 2,237 Answers
If the lamp comes on then shuts off immediately, you may need a new ballast. if it comes on and shuts off when you see a flash of light on the screen, it's a power supply grounding problem and needs to be sent in for repair. if there is no lamp strike and you don't hear a high-pitched whir, the colorwheel is bad. either way, you'll need to send it in for repair. try av solutions (www.avsolutionsny.com). they're pretty good. they are an infocus service center.
Posted on Oct 21, 2009
How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
hi
this lamp has a small lamp pcb with a chip on it.
have u change the complete module or have just changed the bulb.
if you have just changed the bulb then u have to replace the small fuse on the chip.
this should help to reset the lamp timer!
Apr 07, 2015 | InFocus SP-LAMP-LP9 Projector Lamp for...
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
I changed the lamp in my sp7210 the new lamp is working fine but.
just to be sure you have the correct timer reset procedure: power the projector up, press and hold down the 2 brightness buttons for at least 10 seconds. if that doesn't work, you'll need to upgrade the firmware. go to the infocus website.
Jan 18, 2010 | InFocus ScreenPlay 7210 Multimedia...
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
Why does my projector Infocus 7205 says constantly replace lamp and we have a new lamp? Thanks for helping...
On the projector you will see 2 buttons for adjusting the brightness, with the projector on press both the brightness up and down at the same time.
Hold them both pressed for 10 seconds. This will reset the lamp timer.
Take Care!
Nov 13, 2009 | InFocus ScreenPlay 7205 Multimedia...
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
TURN PROJECTOR ON. FAN TURNS ON NO LAMP, RED SATUS LIGHT COMES ON
Bulb timer has expired. Press the left arrow, right arrow and power switch simultaneously for a few seconds. The projector should power up, but this indicates that a new bulb is required and should be fitted as soon as possible, as there is a risk of the old bulb exploding.
Sep 15, 2009 | Office Equipment & Supplies
In-Focus LP-130 and it turns on but the lamp wont fire up, it sounds like the cooling fan goes on and then stops, its a brand new bulb also.. some one said its daughter board that controls the cooling lamp...
the ballast is bad. the fan turns on for the colorwheel, but when the lamp doesn't strike, the fan and colorwheel turn off until it tries again. unfortunately, there are no replacement parts for the lp130.
Jul 17, 2009 | InFocus Office Equipment & Supplies
Sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Jul 09, 2008 | Office Equipment & Supplies
Lamp automatically turns off
Hi there
Did you reset the lamp timer ?
Jan 24, 2008 | InFocus IN72 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
395 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
