Question about Ducane 455 inch 2 - 3 Burner with rotisserie Grill
I have a natural gas grill which I bought used. The burner does not output a lot of heat. The plumber that hooked up the gas says that there is [;enty of gas. Is there a valve that can be adjusted or is something else wrong?
  • 557 Answers
Should be and air to gas mix. Usually looks like a ton flap with a screw in it. It allows more or less air to be drawn in along with the gas.
Posted on Oct 04, 2009
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Can a Turbo STS 3 burner grill (720-0057-3b) be convert from natural gas to propane? Barbeque Galore has gone bankrupt and does not offer any assistance at their 1 800 number and I can't find any...
The original BBQ's Galore went bankrupt, but was bought by new owners, who still operate it as BBQ's Galore. However, they did buy any of the older company's parts supply. However, all you need are the burner orifices for each burner (including the rear burner) and a Hose/Regulator Assembly to connect the grill to the grill tank. Follow the conversion instructions in the Owner's Manual (see link below) and you should be able to do it.
http://www.grill-repair.com/images/grill/turbosts.pdf
I suspect if you call BBQ's Customer Support 800-752-3085. They can provide the orifices, as they are universal in fit. The Hose/Regulator Assembly can be purchased from any hardware store or home improvement center that sells grills and accessories, for about $30.00.
Once converted, you will see marked improvement in the heating capacity of Propane Gas, as opposed to Natural Gas. The grill will preheat faster and maintain higher temperatures longer.
I hope this helped you, Bradley and thanks for choosing FixYa. Happy Grilling!!
Aug 10, 2011 | Barbeques Galore Turbo STS 4-Burner with...
Convert from Gas to Propane - I had this grill converted by a plumber from propane to gas (I believe he changed the nozzles and added a gas line instead of the propane line). I've had to move the...
The "nozzles", as you called them are actually the burner orifice. If you remove the burners and look back into the control panel, you should see the orifices that the plumber installed. They unscrew with a nut driver to be removed. Do this one at a time, installing the LP Gas Orifice immediately after removing the Natural Gas one. Be careful not to mix them up and reinstall the Natural Gas ones.
You will also need a LP Gas Regulator/Hose Assembly to connect to the grill tank, that you will be using. You can pick one up at any hardware store or home improvement center that sell grills & accessories. It runs about $30.00.
Below is a link to the Owner's Manual. But, I'm not sure it will be of help in changing the orifices. But, it's good to have for future reference. You can download and print it.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/80003061.pdf
I hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Aug 08, 2011 | Char-Broil 463254405 All-in-One Grill /...
BOUGHT A BRINKMANN 2545 GRILL LAST NIGHT. WE HAVE IT ATTACHED TO GAS LINE COMING FROM HOUSE. GRILL WILL LIGHT BUT IT IS A LITTLR FLAME AND THE OTHER BURNERS WILL NOT LIGHT?
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
Feb 09, 2011 | Brinkmann Grilling
Converting Thermos Stainless Grill to natural gas
You have to install a conversion kit for it to work the way you want. The reason is because the orifice in either the valves or the main "jet" that feeds the burner tube has to be changed. Natural gas is really not as efficient as lp gas (propane) because it takes more natural gas to create the same btu output as propane.
In short, your grill will not work if you do not do the conversion. I am including a link that lists the conversion kit for your grill, you can order it there and you can download the assembly manual as well.
Here is the link: http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=1723&CategoryID=25
Nov 20, 2009 | Thermos Stainless Steel Gas Grill
New Char Broil gas grill heating issue
Did the kit come with NG orifices and did you use them.
Jun 23, 2009 | Grilling
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
Gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Aug 05, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Low output
The grill is not staying lite and not heating up like it should.
Jul 03, 2008 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Tec grill problem
If mositure gets into the ceramic burners, then yes it is time for new ones. Was your grill also converted over to accept the new gas? Or another thing it could be that spiders are clogging the burner orifice.. If you contact a local dealer on Tec gas grills or someone that can service gas grills. Might be able to help you.
Fireplacegirl
Apr 23, 2008 | Tec RadiantWave Grill
Ducane 455 inch 2 - 3 Burner with rotisserie Grill Logo
52 people viewed this question
Top Ducane Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
