Question about Apple iPod nano
Ipod works on dock but the buttons do not work to go to menu
My daughter owns an iPod nano and the buttons on the wheel does not work when you push them. Is there a way to reset it or to fix this problem??? She can not go to menu or change songs or pause and unpause..........
  • 20 Answers
The click wheel has most likely gone out. Click on the link below to order a replacement. It come with installation instructions, or you may also have them install it for you, for a small fee. Good Luck!
http://store.kokopellimusic.us/ProductDetails.asp?ProductCode=600-2Gen&Redirected=Y
Posted on Oct 06, 2009
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
Remove security code
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 20, 2007 | Apple iPod nano
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
I plugged my IPOD NANO IN TO THE COMP AND ALL **** SET LOOSE, THE IPOD ASKED FOR A RESTORE, WHICH I CARRIED OUT, I THEN EJECT AND ALLS FINE, THEN I RE ATTACH IPOD AND START INSTALLING 1 OR 2 ALBUMS TO...
As follows:
Ipod 2gb hanged
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
Sync problem
Sep 07, 2007 | Apple iPod nano
Ipod Nano Second Generation
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Frozen ipod
Aug 02, 2007 | Apple iPod nano
IPod Nano will not shutdown
turn hold button on and off, then press the menu and centre key at the same time to reset it. T
Jan 27, 2007 | Apple iPod nano
Applie ipod nanao
hi your ipod will shut itself if no action is on you can determine the period of time that will happen good luck
Mar 22, 2006 | Apple iPod nano
Apple iPod nano Logo
143 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
