Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Rheem water heater turns off by its self
My rheem tankless water heater model RTG-74PVN-2 keeps on turning off and flashing 76. How can i solve this problem?
  • 244 Answers
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
  • Michelle Oliver Nov 09, 2009
    Contact Paloma/Rheem customer (800-432-8373) support and notify them you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem.
    Champion:
  • 248 Answers
Overheat stat or fan check fan area for pinhole in littlt hose conn best of luck
Paloma model no. ptg2-42pvp
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Bad remote control, bad pc board, bad wire between pc board and remote control
Gene
Aug 26, 2014 | Rheem Paloma Tankless Water Heaters...
Error code C4 76
Error 76 is communication fault with remote control, or bad PCB board.
Copy following link for Rheem tankless troubleshoot:
Call Rheem, and they will recommend service technician.
800-432-8373
Make sure your unit is serviced yearly to prevent common error codes. Which defeats the robust $100 expected yearly savings from owning a tankless water heater.
Oct 13, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Tankless water heater displays error code
Before calling service technician, copy following links for troubleshoot resources:
Jul 16, 2012 | Rheem RTG-74PVN Indoor Natural Gas...
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
Jan 25, 2012 | Rheem Paloma Tankless Water Heaters...
I have a poloma model/ pt62-42pvn its flashing error code c4 76 i have had no hot water for six days now need help
1) Before calling service technician who can test parts, open following link for Rheem resources including error codes, Rheem chat and phone number, possible manual:
If local technician cannot solve problem, Rheem can probably recommend a person.
2) Error codes are start-point for troubleshooting.
3) Multiple error codes can indicate PC board failure.
If your computer motherboard fails, most people feel the computer is compromised even after motherboard replacement.
4) Error code C7-76 is communication error with remote, and can include bad remote, bad wire to remote, loose wire, or bad PC board.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
5) Error C4-13 can include part failure, vent problem, oxygen depletion, and can also include PC board failure.
http://waterheatertimer.org/pdf/Error-code-13.pdf
6) Tankless routine maintenance manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
7) Some posts about tankless concede that qualified technician was unable to repair unit.
Solve most tankless problems yourself, same day, for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 08, 2011 | Rheem Paloma Tankless Water Heaters...
Can you tell me why my heater turns off when I turn on my washer and the kitchen sink and its not just when Im washing its also when I shower.. and the error code is C76 or Double 00
No I don't know why it turns off and gives error code 76.
Those two things seem unrelated.
Before calling service technician, open following link for Rheem troubleshooting resources.
Error code 76 for possible remote control solution:
Lime build-up is one possible cause when tankless cannot heat water fast enough and turns off
How to delime tankless
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
Apr 20, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Hi. We have a Paloma Tankless Water Heater model no. PTG-74PVN-1 and we keep getting the error C 7-76 or C 8-76. We cleaned the filter but the problem is not going away. The hot water turns off after a...
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 27, 2011 | Rheem Paloma Tankless Water Heaters...
My tankless indoor water heater has an error code C4 76
Error code 76 indicates a communication error with the electronic board and the unit. Call Paloma/Rheem with the serial number and model number of your unit and they will, in most cases, send you a new board with instructions on how to easily replace the board.
Tech Support: 800-432-8373.
Nov 21, 2010 | Rheem Paloma Tankless Water Heaters...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
515 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
