Magnavox LCD TV Power Light Stays On When TV Is Off
I have a Magnavox LCD TV, model 32mf231d/37, and when turning the television off the green power light stays lit for an extended period of time. The screen goes off, but the light stays on. For the past six months the light would go off after several minutes, but starting this weekend the light will stay on for over an hour. Called Magnavox and they were no help. Is this an issue or just an annoyance?
SOURCE: LG LCD TV 32LC4R BLACK SCREEN
same here How do you change the Power regulator?
Posted on Jan 28, 2008
  • 5 Answers
SOURCE: TV Won't come on...
Hello to all from Tom Arnold, WA6OVP
Subject: Repair of computer monitors or flat panel TV’s.
History:
Recently my wife's 27-inch AKAI (LCT21AS) 27-inch flat panel HDTV with DVD player quit working. Years ago, when I had an analog computer monitor quit operating; Joe Fadden WA6DDF had mentioned to me, that often computer monitor problems were caused by the monitor's power supply. Joe also said these power supply problems were often caused by failed electrolytic capacitors. Joe said he was able to fix many computer monitors by just changing all of the power supply electrolytic capacitors. Rather the fix that failed monitor, I just a bought a new one.
Symptoms:
The inoperative HDTV had been bought at COSTCO and had already been returned once to a COSTCO repair center for repairs. Cost to ship and insure the HDTV was 67 dollars. We received back a new HDTV set. Turn around time was over a month, with many long distance telephone calls being required. The new HDTV worked for about three months after it was received. When the returned HDTV failed, it trapped a DVD disc that had been left in the HDTV DVD player. The new HDTV failure symptoms were the same as the original HDTV failure. The red led indication would not change to green when the remotes power on button was pushed. There was no picture and no sound. The remote is required to operate the TV set.
Economics:
My wife's HDTV with internal DVD player was very expensive. Worse yet, the trapped DVD disc was the movie Flash Gorden Space Soldiers 1936. A local TV shop wanted 85 dollars to look at the failed HDTV; repairs were 75 dollars labor an hour plus parts. I quickly figured out that if I could fix the problem it would save a lot of time and money.
Internet Search:
I checked the Internet to determine if other AKAI owners had similar problems with their HDTV sets. There were lots of AKAI 27 inch and 32 inch HDTV set owners listing problems. Without exception all of the complaints concerned the HDTV power supply PC board and failed electrolytic capacitors.
General Internet Consensus:
Most of the AKAI HDTV sets worked just great and that many had been sold worldwide. There were some AKAI HDTV sets that did have power supply problems. Most of the AKAI HDTV set owners were not very pleased with either AKAI or the COSTCO response to the inoperative HDTV power supply problem.
Trouble Shooting:
All electrical power was removed from the HDTV set. The HDTV was placed face down on a workbench with a piece of cardboard to protect the display screen. The HDTV back panel cover was removed. There were many screws of several different sizes. The power supply PC board was separate from the rest of the set's components and was easily identified. The power supply PC board contained several different individual different voltage power supplies. Three electrolytic capacitors located on the PC board had obviously failed. The tops of these three capacitors were puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the PC board were of the switching type. Switching type power supplies are also used in computer monitors to save money and weight.
Power Supply PC Board Removal:
The power supply PC board was mounted to the HDTV back panel with several screws. These screws were removed. There also several multi-pin connectors attached to the PC board. These connectors were numbered with a black felt marker to ensure correct reinstallation. The connectors were Hot-glued in place. A sharp knife was used to remove the hot glue. The connectors were removed.
Repair:
The three suspect failed capacitors were easily removed. The three capacitors were each 1000 ufd and rated at 16 working volts. The other power supply PC board electrolytic capacitors were visibly checked. Three new capacitors were installed, they were rated at 1000 ufd at 25 working volts. On the PC board the three electrolytic capacitors were in just one of the power supply circuits and were identified as EC18, EC19, and EC20.
The New Electrolytic capacitors:
These were low impedance / high reliability radial lead polarized aluminum capacitors, they have a plus and minus connection pins. Correct installation of any polarized capacitor is required. The three new electrolytic capacitors were specifically designed and rated for service in switching type power supply circuits. Switching type power supply electrolytic capacitors need to be both very robust and designed for use in high frequency circuits. General-purpose aluminum electrolytic capacitors should not be used in switching type power supplies, if capacitors designed for switching power supplies can be obtained.
Final Repair Steps:
The PC board was reinstalled without the electrical connectors to the PC board being hot glued. The HDTV back panel cover was refastened. Watched episodes one through five of Space Soldiers. It was well worth the time and three electrolytic capacitors to fix the problem. The repairs saved a lot of time and money. The repair was very simple and not the least challenging. It took longer to remove and then reinstall the HDTV back cover panel than it took to replace the three failed capacitors.
Safety:
These types of repairs should not be attempted without a complete understanding of the dangers involved with working on electrical equipment, especially working around power supplies and charged capacitors. Proper desoldiering and soldiering techniques need to be used.
Conclusions:
Flat screen computer monitors and TV sets do fail. Repairs of electronic equipment can be very expensive. When your computer monitor or flat screen TV does fail, you might consider a visible inspection of the equipments power supply. A simple repair might save you a lot of time and money.
Posted on Aug 21, 2008
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
SOURCE: magnavox 42mf230a/37 television. it has
When this happens the first thing to check is the Power Supply, you need to check, that, and all the voltages coming out, ensure the voltages are correct. You MUST get a Service Manual. I have searched for a free one, but the only ones I could find were pay for? Link below.
https://www.completeservicemanuals.com/.../magnavox/.../cat_89.html -
What you are experiencing is a symptom, the cause lays elsewhere. Something is shutting down the PSU, either a fault IN the PSU, or elsewhere causing it to shut down. It can be quite a number of things that can cause the same symptoms. Please get a service manual and work through the troubleshooting procedures, to even have a shot. I repair these things all the time, I can tell you from experience, it is NOT easy. Good Luck. Should you NOT choose to do-it-yourself, Please ensure you get a firm "Quote" from the qualified repairer before allowing work to commence.
Posted on Mar 18, 2010
BoiseLCD
  • 63 Answers
SOURCE: My magnavox 32mf231d/37 tv will power up and the
Try taking it for a walk, or sing happy songs to it.
Depression is a common problem with today's LCD panels.
Most cases go untreated.
Talk to your doctor about receiving medication that may be able to help with it's symptoms. Side effects include nausea, diarrhea, genital warts, hemorrhoids, and an erection that lasts longer than 4 hours.
Do not watch your TV if yo are pregnant or using an MAOI, as these combinations have been known to cause permanent death.
Posted on Jun 14, 2010
I have a 32" Magnavox tv purchased in 2005, model
dear User,
pls be informed that supply capacitor are weak.
kindly change the supply capacitor
Feb 26, 2011 | Philips 32MF231D Television
37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 29, 2010 | Philips Magnavox 51MP392H Rear Projection...
Hissing sound from speakers and the picture turns off.
That model set was known for Chinese capacitors that failed, replace the power supply or look for bulged caps and replace them if your able to
Jan 06, 2018 | Philips 32MF231D Television
Magnavox 32mf231d - Just a blinking green light, No Power
I had this problem, but saw other places that it was a cheesy capacitor on the power supply circuit board causing this. I opened it up and took the power supply board out and it was obvious which capacitor was bad...top was bulging and had black stuff on it. It was rated 2200 uF @ 25V...got a new one @ Radio Shack that was 2200 uF @ 35v. Soldered it in (I stink @ soldering, but gave it a shot and it was EZ). Watching the first weekend of college football w/o waiting on a flashing green light for up to an hour so the TV would start! I'm going to try to find the other websites that directed me to this to say THANK YOU...BTW my brother used to have fits with several Magnovox TV's and thier power supplies back in the old tube style TV days. I thought I didn't need to worry about this with an HD flatscreen, but was wrong. I will think twice before buying a Phillips/Magnavox/Funai/whatever else they are again. They have a long list of complaints and I believe a class action lawsuit to refer to about this problem. They should have stepped up and done something!
Mar 19, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
32 inch tv, 32mf231d/37 light blinking
There two caps on the power supply that the tops will swell up. Change them both and that should get you going.
Sep 05, 2008 | Philips Magnavox 27MS343S 27" TV
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
