Question about Guillemot ThrustMaster Top Gun AfterBurner (2969038) Joystick
Doesnt work when i push or pull on the stick
Everything on my joystick works except for pushing up and pulling back on the stick...any ideas. playing fighter ace
  • 31 Answers
If it's anything like an authentic joystick control, there may be a switch where your fingers rest which must be gripped/engaged in order to achieve movement, but i've never actually seen this controller so I can't be certain.
Posted on Oct 04, 2009
How do you reset the chair when all the lights are flashing?
Hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
May 30, 2014 | Pride Jazzy 1103 Ultra Standard Power...
Xbox 360 left joystick is going up when i need it to go down and down when i want up
When my kids controller does that sometimes taking out the batteries works
Mar 11, 2014 | Microsoft Xbox 360 Wireless Controller
How to fix 1-2 beep code on gateway dx4870-ub20p
Most computers come with 2 sticks of RAM. If yours only has one skip to the bottom.
Step 1
Start by reinstalling your RAM memory. Pull the pins on each side then remove the sticks of RAM. They should be in there pretty firm. DONT wiggle them out, just pull straight up. Then put them back in with the pins still "out". They should be firm to go in as well, again DONT wiggle just push straight down. Both the side pins should lock into place on there own once the RAM is back place properly.
Step 2
If this still doesnt solve it, pull both back out and only put one back in. If that doesnt work, put the other one in only. If still not working try the next step
Step 3
Uninstall all Ram sticks and reinstall just one in one of the slots. If that doesnt work install same stick in a different slot. If that doesnt work, use a different RAM Stick.
Nov 20, 2013 | Acer Computers & Internet
How do i reset a jet 7 mobile wheelchair
did you put it in lockout accidentally? try this! turn off chair, press and hold the on button till a beep is heard, push and hold the joystick forward till a beep is heard, then pull back and hold joystick till beep is heard, turn off, and turn on. it should work now?
Sep 04, 2012 | Jet 7 Portable Power Chair
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
Throttle stick not working properly.
take it back to seller heap of cr*p
Jun 20, 2009 | Ubi Soft IL-2 1946 PC
Car stereo wont accept disk (motor doesnt pull it in)
you are correct it is not "seeing" the disk with it's infared sensor to repair this sensor you must disassemble the radio
Apr 30, 2009 | 2007 Ford Focus (3 Door) Hatchback
No signal for joystick
If there is no light on the receiver then I'm sorry to say it might be fried!... Try unplugging and leaving it for a while ... I know that seems like a bit of a whacky idea but this often works with some hardware I have come across
Apr 21, 2009 | Computers & Internet
Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Sep 16, 2007 | Microsoft Xbox 360 Controller
Guillemot ThrustMaster Top Gun AfterBurner (2969038) Joystick Logo
204 people viewed this question
Top Guillemot Video Game Consoles & Games Experts
James Wishart
Are you a Guillemot Video Game Console and Game Expert? Answer questions, earn points and help others
