Question about RCA D52W19 52" Rear Projection Television
My tv won't stay on when i turn it on - RCA D52W19 52" Rear Projection Television
Toshiba tv won't turn off/ stay on
Try unplugging your television for a half an hour or so. It might reset to original settings, Your problem might be input lock features. If you can get to the menu after unplugging your tv for awhile we might be on the right track. I'm just looking thru a Toshiba manual that I have.
Apr 13, 2013 | Televison & Video
The tv usually turns on but all of a sudden it won't. When it does turn on it makes a loud noise like a boat. Someone told me its the fan but I'm not 100% sure though. The noise stays on until the tv
Sounds like the motherboard on the TV has failed. Would recommend replacing the TV or taking it to a TV repair shop which may cost more than just replacing it.
Jan 30, 2013 | Televison & Video
Won't Stay On TV MODE.
What I need to know aside from brand and model number is does the set have a button that changes this feature or the player?
Dec 21, 2012 | Televison & Video
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Dec 20, 2012 | Televison & Video
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
Rca 20f512 tv won't stay on
Here is a troubleshooting guide for you:
Flyback Transformer
must have supervision of a qualified service technician
Sep 23, 2012 | RCA 20F512T 20" TV
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
