Question about Acer Aspire 3690-2196 Notebook
Lines in middle of screen not sure if display or yideo card if i squeeze display on sides slightly clears up but then returns
  • 408 Answers
Either the screens not grounded or there is a short in the wires to the inverter or screen.
Posted on Oct 10, 2009
Trio stealth tablet theres a line down the middle and black and white one side and color on the other
Sorry to hear this Jennifer. First thing that comes to mind is that it is a crack in the under screen glass. You can test this by applying slight preasure on each side and see if you see any rainbow colors or if you lose the PITURE on the screen. Has it show a screen on both sides of the line? These tablets are known to have issues relating to even the slighted shock or sometimes its caused due to surges from the charge unit. If you have this happen and it does get worse it is about 40 dollars to have a new screen installed. Ill follow your post to see if I can help you further.
Good luck
Chadman
Nov 11, 2014 | Tablets & eReaders
How to apply screen protector?
The screen should be cleaned thoroughly with an alcohol pad leaving no lint/dust. Then peel the back of protection screen off halfway, line up the peeled part on screen to your liking then use a credit card to push towards the end you haven't peeled yet while pulling the remaining backing and pushing the credit card from middle to edges.
Aug 30, 2014 | Ericsson SCREEN PROTECTOR MEXXPROTECT...
My asus laptop display is showing a blue or purple haze bar through the middle.
sounds like you are right there do it before the warranty runs out!
Dec 09, 2012 | ASUS G73JHA1 Notebook
Tv flat screen only half the screen works rest is black
This is casued by the buffer boards on the right or left edge of the plasma tv. You need a direct replacement for the top buffer and then your picture will return!
Please rate if this helps!
Parts are found on ebay or shop jimmy
Mar 07, 2011 | Sony 50 in. Plasma TV
I have a light pink Sony Vaio VGN-CR510E and i've had it for a little over two years now. The screen has gone grey/white and will only return to the natural screen when the tops of the screen are squeezed,...
I wouldnt say beyond repair, if you were able to compress it and the screen would appear normal there is a connection problem, your monitor has small connections making it work one happens to be an inverter. It could be that the connection is loose, the bad thing about that is if its loose there is a chance it could cause a short which in return you will need an inverter or whole monitor.
1. try hooking it up to an external monitor, you need a vga or dvi cable and try hooking up to a projector or another monitor, if that doesnt work its your video card. unfortunately either fix is somewhat expensive. Good luck and please vote thank you.
if you have have hooked up an external monitor before here are some instructions
1. make sure the power is off
2. plug the vga cord to your laptop and to the external monitor, 15 pins normally blue or back has 15 little holes ive seen some that are pink.
3. turn both on
4. you may have to hit a function key thats the fn button plus (on mine is f4 small rectangle with a line on each side of it .
5. if the external monitor works then your monitor or the cables to your monitor are bad
6. if the external monitor doesnt work its your video card and you will need a new motherboard if the card is integrated.
Feb 18, 2011 | Sony VAIO VGN-CR510E/L Laptop
Vertical lines in screen
grab your screen in the middle at the top,and flex it lightly,,kind of a twist ,does the screen change or the lines apear and move around,if it does check display ribbon at hinge for damage,and connection to graphics card,run dual display in clone mode with external monitor or tv,are the lines on it too?if they are .try reinstalling your graphics driver,and software,
Oct 06, 2009 | Computers & Internet
My EV 700 screen picture is condenced has one bright clear line in middle screen and two more lines faded,space in between lines
Sounds like a CRT problem but to be sure, hook up another monitor to the computer and if you get the same exact lines then you know its a problem with the video card, if the lines go away then you know its a problem with the monitor.
Jun 09, 2009 | Gateway EV 700 17" CRT Monitor
Slight starbursting on each side of screen.
adjust the horizontal size to hide the lines
Jan 10, 2008 | Toshiba 32AF43 32" TV
Vertical Line in center of screen
never heard of so called card myself but ,is the line your talking about from top to bottom or from side to side in the middle?straight across middle is called horizional which means vertical problem so you have either bad capacitors 35uf 100v ,1uf 50v, or bad vertical output ic.
Dec 26, 2007 | Curtis-Mathis CM32010 TV
Acer Aspire 3690-2196 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
