Question about Sony HVR-S270U DV Camcorder
Split rubber anyone any ideas how do i join it? - thanks
  • 403 Answers
You can try two options. Go to an automotive store and get a rubber gasket repair kit. Or you can try a two part epoxy that works with rubber also. I have you the two part epoxy and it worked great. Just use rubber gloves and have some tooth pics close by. Use the tooth pics to scrap off any extra compound off of the area your trying to repair. Hope this helps. Let me know if I can help you with anything else.
JimmyC
Posted on Oct 04, 2009
Bosal towbar wiring problems....
Did you ever solve the problem with the location for the orange wire as I have exactly the same problem, thanks
Apr 22, 2013 | Cars & Trucks
Hotpoint tcl770 belt split
all you need to do is remove front panel pop the top off remove the two screws on the in side pull the panel up. Now you have access to dryer changing the belt is a pain if you have big hands but they give you room to get one of your hands in there
Nov 16, 2011 | Washing Machines
Wont start
Try looking for leaks in the rubber that joins the carb to the cylinder, easiest way to do this is spray a bit of easy start around the rubber area when cranking the engine over. try squirting a bit of easystart into the airbox air intake first to see if it will start with that first, if it does then you need to look at your carb settings as per manual.
Apr 14, 2010 | 2000 Cagiva Planet
CBR600 CAMCHAIN
i have change mine with open motor while reparing my transmission and i`m not sure that`s a good idea to change it in place, but if it`s work you will save time. I took about 8 hours to close transmission and motor and take it back in place.
Mar 30, 2010 | 1992 Honda CBR 600 F(2)N
Compressing the file
1. Download HJ Splitter. It is used to split and join LARGE files. But the end receipient too should have it to join the files back.
2. Split the files>compress individual files>mail them.
3. hjsplit.en.softonic.com
May 22, 2009 | Computers & Internet
Dual shock controller 3 for PS3 joystick needs repair
they sell repacement thumbsticks on ebay they are like 5 for 3.99 with free shipping i hear its pretty easy to replace
Mar 09, 2009 | Sony Dual Shock 3 Controller for...
A smell of burning rubber is coming from my engine. What is it? Could it be the timing belt? Is it safe to drive any distance? Thanks I have a burning rubber smell in my Subaru 2003 Outback, - any...
Check serpentine belt, the radidator hose , the air conditioner compressor and also the differential seal they common cause for rubber smell.
Check for any rubber part that can be in contact with exhaust system and inspect wirings looking for shorts.
Also ensure that the smell is not coming from a bad tyre, and check for oil leaks in your engine, burnt oil can be confused with rubbere smell.
Mar 05, 2009 | 2003 Subaru Outback
Toilet pan installation procedure
Hi muller2012,
I'm Harvey the Master Plumber.
Your question is: the procedure to join pan to waste pipe without leaking. do i silicone around rubber seal?
In 30 years this is the first time I've heard of a toilet "pan". If you're refering to the bowl, it connects with a wax ring and a pair of bolts. You then caulk around where the bowl meets the floor to keep cleaning liquids from getting under and getting stinky. If this is not a standard toilet it would be a good idea to post pictures and give make and model.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Oct 14, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Ge nautilus dishwasher--leaking when running
Hamms4
Wonderful - Hope you've got some satisfaction from repairing and resolving the problem
Kind Regards
TC
Aug 22, 2008 | Dishwashers
Sony HVR-S270U DV Camcorder Logo
63 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
