Question about Whirlpool 21.6 cu. ft. / 612 liter Chest Freezer EH220FXKQ
Old Whirlpool chest freezer where is temp setting?
I received an old 18.5 cu ft Whirlpool chest freezer. I've cleaned it up, and plugged it in, and I can hear it running fine, but the sticker on the inside says to start with the temperature setting at 3. I've looked around, but where do I set the temperature at? Do I have to take the panel off the end? I've put several bottles of water in it for now to see how long they take to freeze, but want to make sure I get it to it's optimum performance.
Thanks in advance.
Merry
  • 126 Answers
Its either at the top back of freezer or lower sides
Posted on Dec 22, 2007
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Sear chest freezer stop working model#2539139180
The compressor probably shut off on thermal overload. This protects the compressor from burning up. What has happened is that a capacitor or evaporator has gone bad or it could be low on freon. Have someone take a look at it. However, if it is older than 8-10 years old, consider replacing it. This could be the beginning of the end.
Feb 02, 2013 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Kenmore 6.9 cu. ft. chest freezer stopped working
It looks like a bad ignition switch or capacitor. This is not that expensive. Probably not the compressor. Unfortunately, one small part stops the whole show.have a friend who is a tech look at it.
Jan 24, 2013 | Freezers
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    How long should it take for a 18 cu ft. chest type deep freeze to get cold?
    From room temperature if just plugged in rule of thumb is 24hrs to properly reach temp. Place a glass half full of water in shelf when is frozen solid the unit should be plenty cold enough to keep food. It is always a good idea to get a small fridge thermometer to make sure of temp.
    Oct 26, 2010 | Whirlpool Freezers
    I am just trying to find out what are the recommended settings for a 8.8 cu. ft. energy star rated Frigidaire chest freezer.
    I would suggest getting a fridge/freezer thermometer and use that to set the temperature. They are marked with the recommended temperatures. Also many times the setting on the nob in the freezer are not very consistent so it is better to actually set the temperature by turning the knob up or down to reach the desired temp on the thermometer
    Sep 18, 2010 | Frigidaire Freezer 8.8 cu. ft. Chest...
    We have a 21 cu ft 2009 chest freezer. It is not
    Is your circulating fan working?
    Sometimes they stick and need a shot of WD 40 and then work
    it back and forth a little until it wants to take off again. Keep me informed
    and PLEASE give a Thumbs Up for the effort. The Raz Shack
    Jan 08, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
    Whirlpool 21.6 cu. ft. / 612 liter Chest Freezer EH220FXKQ Logo
    333 people viewed this question
    Top Whirlpool Freezers Experts
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    Justin Duby
    Justin Duby
    Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
