Question about Philips Magnavox 42MF521D/37 Television
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an occational flash of the channel number and like it was trying to display an illegal color has a few lines of color then blanks till the channel is changed again.
    Scholar:
  • 105 Answers
Hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Posted on Oct 05, 2009
I have a Magnavox 32MF337B/27 the tv turn's on 2 sec later it turn's off.
Check inside for Bulging electrolytic capacitors and replace them. Samsung was famous for it.
Feb 03, 2013 | Televison & Video
Magnavox TV turns on and shuts off
This is on protection mode as something is loading it on switch on from the secondary power supply. This might need attention of a qualified service technician.
Jul 12, 2012 | Philips 32MF337B 32 in. LCD Television
Am I diagnosing the problem correctly?
Sounds like a bad component in the power supply. Most likely a bad capacitor.
Nov 16, 2011 | Televison & Video
Power will not stay on , on my magnavox tv model 32mf337b/27 unplugged like user manual suggested but didnt work even after 30 hrs saw on magnavox.com a few people have had same proble with this model mine...
Magnavox has issues with puffed caps on the power supply. This sounds like its a 32 inch lcd tv. I tried searching for a service manual for this and can't find one. If it is an lcd you need to look at the capacitors on the power supply. If they are puffed up, you will need to replace them with equal or slightly larger valued capacitors. The capacitor values are mfd and voltage printed on the capacitors themselves. You will need a soldering iron to replace them. Lay the tv, if it is an lcd, on a flat surface cushioned by a blanket. Make sure the surface is large enough to support the tv frame, as you don't want to cause damage to the panel. remove the back of the tv. There are numerous screws, and once the back is off, check the power supply pcb for puffed caps. This is the board with the power cord attached. I know in magnavox tv there is a cage covering the power supply, so remove any connectors because you will have to flip the cage housing the power supply to get to the caps. If you feel confident, give it a try. Let me know how it goes
Apr 03, 2011 | Televison & Video
1 Magnavox 32" LCD HDTV MAG 32MF337B
Replace your capasitors on the power circuit board.. They are junk to begin with.. They are cheap.. Thats all i can suggest..
Nov 26, 2010 | Televison & Video
TV will not power on
Yes,power supply board have dead capacitors leakage problems.These capacitors useally bulge up or burst open.U know how to solders?Look in the power supply board rerplaced these capacitors will solved the power problem.Or tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 11, 2010 | SNK Magnavox 32MF338B27 32 in. LCD TV
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
WHAT IS THE CODE TO PROGRAM A J.V.C. DVD INTO A PHILLIP UNIVERSAL REMOTE?
Apr 08, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox 27
THANKS FOR THE INFORMATION ThaMp3DOCTOR. PRESSING THE VOLUME+and CHANNEL+ SIMULTANEOUSLY FOR 5 SECONDS WORKED!   THANKS
Mar 15, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 42MF521D/37 Television Logo
1,477 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
