Question about Epson Stylus Photo R1800 InkJet Printer
Sheet feeder refuses any weight paper the sometimes just feed it through blank
Tonerman
  • 62 Answers
SOURCE: Auto Document Feeder
has the feeder attempted to feed in the document ? Check to see if there is already a document on the copyboard platen
Posted on Apr 29, 2007
checkitright
  • 1362 Answers
SOURCE: HP Laserjet 1320 Paper feed malfunction
Solution,
 take out the tray
if you look on the bottom of the machine there is a metal plate.
in the middle of the plate there is a bump
turn the tray upside down and look at the bottom, there is a small hole with a plastic lever. it is probably broken.
when the tray is slid into position the lever hits the bump and releases the lifting mechanism.
replace that part or the tray. I can get you a new tray e-mail me at
pakapala@gmail.com
Posted on Oct 18, 2007
IB4G2008
  • 3587 Answers
SOURCE: Printer won't stop jamming
sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
Posted on Mar 08, 2008
SOURCE: Paper won't load. Media loaded incorrectly.
Okay.. 1st off I'm probably going to the jumped on for this... But.. I fix and/or make them work printers, computers and all sorts of electronic gear. For a living... Yes .. the manufacturer will tell you not to use alcohol to clean the rollers. but it does work. Windex (ammonia) will clean the heads at times. I also use Scotch brite pads to clean the pickup rollers. We get them in about 8x10 inch pads.
I will spay some alcohol on the end where the pick up roller is. Place the pad in normal paper tray. Most printers have a cam shaped one on the right, left or in the middle. That gets the paper moving. The pad is way to thick to actually move and will cause a jam indication on the printer. But what happens is the roller will slip on the pad and clean itself. Pretend you cleared the jam a couple of times and the printer will try to pick up the 'paper' and jam again. A couple of these and the pick up roller (cam shaped) will usually be good to go. The other option (the best) is to buy a new pickup roller for the printer. But cleaning will work for the short term. What happens on most printers is the roller gets very smooth from normal use and then won't pick up the paper for the rest of the trip through the printer. I have used a piece of fine grade sand paper, but you have to hold it so it won't go through the printer and it makes a gritty mess... Once I orderd a 'printer cleaner' from HP and all it was, was a couple of pieces of scotch brite glued to a fancy holder to match the spacing of the rollers. That's when I started using sheets of the stuff. Just pretend they are a piece of printer paper. In the worst case I have used belt dressing and then alcohol to clean most of it off. Alcohol has a tendency to soften the rubber on the pickup roller. That's why the company says don't use it. But you can by rubber rejuvenator that is mainly alcohol.. Go figure.........
Posted on Mar 21, 2009
  • 1684 Answers
SOURCE: paper feed feeds more than 1 sheet at a time
he problem you are having is caused by a worm separation pad assembly. This assembly is what separates the paper into individual sheets. It takes about 30 minutes to disassemble the printer and replace the part. Most printer repair shops will do the repair for you but the cost may be a bit much. If you are interested in doing the repair yourself we do stock the part. We can provide the separation assembly and a service manual on CD that gives directions for replacing the parts plus other information about the printer. The part and guide runs $14.95 plus shipping. Let me know if you need one, tech
Posted on Apr 27, 2010
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
    SOLUTION(S): Reset the Sheet Feeder Gears
    If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
    alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
    home position, which may not be possible if the paper stop cam is not in the correct position.
    PROCEDURES
    1. Remove the sheet feeder from the unit.
    2. Remove the sheet feeder motor from the sheet feeder assembly.
    3. Remove the drive gear from its spindle.
    4. Realign the lifting tray gear and paper stop cam gear.
    5. Reinstall the drive gear and sheet feeder motor.
    6. Reattach the sheet feeder to the print unit.
    7. Reassemble the unit.
    Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
    Paper feed on Canon i 350n ink jet printer
    If the paper is lodged too far into the printer and can't be removed:
    Press the power button to turn the printer off.
    Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    Close the front cover.
    Press the power button to turn the printer back on.
    Resend your document to print.
    Ensure that:
    The paper is a recommended paper for inkjet printers.
    You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    The printer is on a flat, level surface.
    The left paper guide is against the side of the paper.
    You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    The left paper guide does not cause the paper to bend in the sheet feeder.
    Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    Envelopes or the appropriate specialty papers are selected in the printer driver.
    You are using a paper or envelope size supported by your printer.
    May 13, 2008 | Canon i350 InkJet Printer
    Blank lines and doesn't feed properly
    Please clean the print nozzles :
    1. Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    2. Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    3. Continue doing this until it looks clean.
    4. Then dab the cartridge on the towel to make sure the ink is flowing.
    5. Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
      1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
      2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    1. Paper jam:
    1. Press the power button to turn the printer off.
    2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    3. Close the front cover.
    4. Press the power button to turn the printer back on.
    5. Resend your document to print.
    Ensure that:
    • The paper is a recommended paper for inkjet printers.
    • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    • The printer is on a flat, level surface.
    • The left paper guide is against the side of the paper.
    • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    • The left paper guide does not cause the paper to bend in the sheet feeder.
    • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    • Envelopes or the appropriate specialty papers are selected in the printer driver.
    • You are using a paper or envelope size supported by your printer.
    May 10, 2008 | Dell 922 All-In-One InkJet Printer
    Won't feed paper while printing
    I just obtained a printer with the same problem. When I opened it up I discovered a plastic gear that had cracked and was not turning the main paper roller as it was slipping. It looks like the solution is to replace the roller if you can find one or to repair the gear and epoxy back onto the roller. I am trying the later.
    Apr 22, 2008 | Lexmark X83 All-In-One InkJet Printer
    Canon Pixma mp510
    The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
    Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
    Paper jam light is on
    Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
    Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
    Sheet feeder isn't working
    which feeder? for the oringinal copy? or the blank paper. Either way it sounds like the rubber feed rollers need to be cleaned. With a rag and some rubbing alcohol clean all rubber rollers.
    Jun 28, 2007 | Canon PIXMA MP830 All-In-One InkJet...
    Epson Stylus Photo R1800 InkJet Printer Logo
    32 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
