Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series numbr CS0318980 stopped mid cycle, no power, water still in the tub... dead as a door nail. Already checked power... We also can't tell by our serial number what year we made our purchase. Thanks for any help!!! The water is just sitting! help.... Jim
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (Usually a number such as 110.######) and you'll see a list of major sub-components with diagrams and parts. You should be able to find the model number on the cabinet after lifting the lid.
If you cannot hear the motor turning at all, the problem points to one of a few places.
1. The timer. Check to see if it is moving at all.
2. The timer motor, this drives the timer.
3. The Lid Switch, If this is bad, the washer won't get into drain / spin mode.
4. The motor or capacitor themselves.
Following is the Whirlpool PDF on top load, direct drive washers with a troubleshooting section and sections on testing components.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Oct 04, 2009
Kenmore washing machine 80 series won't spin or add water to the tub
Plug on motor (Multi-plug) may have a burnt out wire as it has different speeds. Remove and check the plug (top comes off). Any burnt wire needs to be cut back to clean copper and refitted into plug.
Dec 07, 2013 | Kenmore Washing Machines
Water will not drain. sewer line is not pluged. Customer service says I could have a plugged filter at the pump ( we have dogs). How do I get to the pump to unclog it. Model EIFLS55IIW woody
Hi agnes! Washing machines, including those built by Frigidaire, have internal pumps. These pumps help drain out the water from the washer tub between the wash, rinse, and spin cycles. If the pump is damaged or the pump pulley system is frozen/stiff, the water can become trapped in the washer tub. In both cases, the pump assembly needs to be replaced. You can check by looking for a few signs that a pump is dying or already dead.
1 Start the washer and wait for the washer tub to fill with water. If you do not hear water or hear a motor whirring, the washer motor may be dead.
2 Open the washer lid in mid-cycle. Note whether or not the inner tub is still spinning around. The inner tub is the inside surface of the washing compartment with many holes for water draining. If the tub is not spinning but the motor is running, it is possible the pump is dead. Check the pump pulley by removing the pump from the washer and trying to rotate it by hand. If the pulley doesn't turn freely and is frozen or stiff, replace it. Also, if the agitator is moving but the tub isn't, this is a sign the pump is dying. For front-loading washers, do not attempt to open the door mid-cycle. Look through the glass door. If there is enough water to come up against the door, the pump is malfunctioning.
3 Wait for the washer to finish its cycle. Open the unit. If water is still in the tub, the pump is likely dying or dead.
Sep 04, 2013 | Electrolux EIFLW55I Washer
80 model series wont go into the wash cycle and does not stop filling the tub with water causing it to over flow
Check the pressure switch and the lines going into it for blockage. The video below will walk you thru the process.
Jan 01, 2011 | Kenmore Washing Machines
My Kenmore 80 series. did not spin
most common problem is either the lid switch (made no sound) or the drive coupler(sounds like its working but no spin) also check for anything holding tub(nail trough basket jamming tub etc.)
Jun 11, 2009 | Kenmore 22422 Top Load Washer
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washer over flows
Dear Cbelton
please inspect the following
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
  • please rate this solution.Thank You..
    Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    110 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
